EM TuningSky Insurance
    imported_GarretLogan
    complete ECU upgrade
    This might sound random, but I was wondering if there was a mod on the market that would allow not only for an A4 to be chipped, but also one that would allow more functions in the center display area. It would take the normal mileage and fuel efficiency readings, then it would add upgraded gauges like a 911Turbo or GT2 (boost readings, engine performances, etc.) The reason that I place the two together is because I figure that you may have to completely swap out the ECU. Might as well hit two birds with one stone, any ideas?
    Mar 2004
    USA
    275
    Re: complete ECU upgrade
    Two separate issues actually.
    1. You can have the car chipped - I'm assuming the engine is the turbo, because the non-turbo odes not benefit from chipping.
    2. You can have some or maybe all of these display ideas modded into the display via A VAG modification. Some guys in the states have played around with this.
    Nov 2003
    Wa, USA
    248
    Thats a good question. I remember seeing, a while back, of an A4 will other options on thie cluster. the one i remember had his boost guage as an option. I want to do that too, any idea how to do that?
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Try this link.
    Link
    Mar 2004
    USA
    275
    That's the one!
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    I'm a treasure of info and links me [img]/ubbthreads/images/graemlins/wink.gif[/img]
