JMB RetrofitsChris Nott
Results 1 to 7 of 7
Thread: Clocks/immo2
    951
    951's Avatar
    Feb 2007
    North east
    493
    Clocks/immo2
    I have just got some S4 clocks(98/98),they physically fit my car and all the plugs are the same and everything functions apart from the obvious the car wont start,i was just going to swap the faces/needles onto my old clocks but it would put the speedo out by about 5mph so How and where do i go about getting the clocks coded to my car ??
    A4 Avant 1.8T Sport (183 bhp).
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Did you make a note of your old soft code? As you will this to code onto the S4 clocks with VAGcom. Then log into Instruments, then adapt IIRC read, then save, immo light will go out. Turn ignition off then back on and away
    951
    951's Avatar
    Feb 2007
    North east
    493
    I have no idea what the soft code is,where do i find that out ??,also i dont have vagcom,can you get the codes with a snap on diagnostics scanner ??
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,378
    Umm, Mark that wont work unless you happen to have the matching keys for the S4 dash.....
    The keys are matched to the immo unit, and the immo unit is then matched to the engine ECU. That procedure is only if you've changed the engine ECU. If you've changed the immo part the keys arent known to the immo box, so you wont go anywhere.
    What you need to do, is dig the SKC code out of the new dashboard using Vagtacho, then use that SKC code to code the new dash to your keys and then your ECU.
    There was a post on here by one of the chaps that did just the same thing, using an S4 clock set into a 1.8T iirc.
    Have a search for it.
    TD5 Land Rover Defender build
    Apr 2004
    12,520
    DOH !!! For some reason i gave him ECU changing instructions........
    Kev is right, you need a vag tacho cable and software, can be had from Ebay for 40 ( i think thats what mine costed )
    Sorry for the mis information, i had brain fade from the poilsh fumes doing the cars,lol
    May 2009
    32
    iv'e just had some clocks coded in by the dealer it cost 25 quid as i no someone who works there, they will prob charge about a hours diagnostic labour which is prob about 80 quid
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    ive got perfect working s4 cluster in mine, as already said you need 4 digit skc to code in keys (if using vagcom), and softcode from old clocks to convert them to work in a 4 cylinder although its easy enough to work out with info on ross tech/vagcom site
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
