Volks AutosEM Tuning
Results 1 to 10 of 10
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    k03's with 12 blades?
    i have my turbo off just now and its a k03s (well i hope so). the part no is for a k03s and it is a 1.8t quattro so should have a k03s but it has 12 blades on the compressor,should it not be 8? i hope its not a k03 with the plate from a k03s on it.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    whats the part number?
    12 blades is a normal k03 afaik
    TD5 Land Rover Defender build
    May 2008
    perth
    1,197
    058 145 703LX is the number. as far as i know it should have 8 blades. if it turns out to be a normal k03 i will only be making about standard bhp with my chip.
    "Stick a V8 in it!"
    15,370
    Well that part number is listed for the AEB right back to 1995, so its most certainly not a K03S
    which Engine code do you have? i THINK the 1.8TQS is an "AJL" which means the correct turbo is infact: 058175703J (or JX presumably)
    Interestingly that turbo is also listed for the APU, AWT and ANB, which afaik are all 150hp engines, albeit later ones.
    May 2008
    perth
    1,197
    i put a post up a while ago and siena said that was the part number for the turbo on an AJL 1.8t quattro sport. thats just ****ed me right off if i have only got a k03! i mean it goes ok but i will prob be about 190 at a push instead of about 210.
    "Stick a V8 in it!"
    15,370
    well i just looked up vagcat, and put in 2000 A4 quattro, and looked up turbocharger
    it lists two PN's the one you gave me and the one i gave you, but only the one i gave you is listed against the AJL
    May 2008
    perth
    1,197
    so does that mean they came standard with a k03 or a k03,s? i mean it goes ok the way it is but now i will always be wandering if i should have about 25bhp more or not. it does look like the turbine from a k03 with the 12 blades anyway. is the inside dia to the turbine where the inlet pipe goes on the same on both?
    "Stick a V8 in it!"
    15,370
    The standard turbo for the AJL is the one with the J suffix. The L suffix (or LX which just means an exchange L) is the normal K03 used on AEB's and the like.
    the J suffix is also listed to fit the later B6 1.8T's with the 163/190hp engine (BEX and BFB engine codes amongst others)
    May 2008
    perth
    1,197
    looks like i will be looking for a k03,s then.
    Project Plush
    Oct 2006
    Sudbury, Suffolk
    689
    Ill have to check mine at some point...
    Drizz Developments - Audi A4 Avant Quattro Sport
