i have my turbo off just now and its a k03s (well i hope so). the part no is for a k03s and it is a 1.8t quattro so should have a k03s but it has 12 blades on the compressor,should it not be 8? i hope its not a k03 with the plate from a k03s on it.
058 145 703LX is the number. as far as i know it should have 8 blades. if it turns out to be a normal k03 i will only be making about standard bhp with my chip.
i put a post up a while ago and siena said that was the part number for the turbo on an AJL 1.8t quattro sport. thats just ****** me right off if i have only got a k03! i mean it goes ok but i will prob be about 190 at a push instead of about 210.
so does that mean they came standard with a k03 or a k03,s? i mean it goes ok the way it is but now i will always be wandering if i should have about 25bhp more or not. it does look like the turbine from a k03 with the 12 blades anyway. is the inside dia to the turbine where the inlet pipe goes on the same on both?
The standard turbo for the AJL is the one with the J suffix. The L suffix (or LX which just means an exchange L) is the normal K03 used on AEB's and the like.
the J suffix is also listed to fit the later B6 1.8T's with the 163/190hp engine (BEX and BFB engine codes amongst others)
