Sky InsuranceAH Fabrications
    floyd 1.8 turbo's Avatar
    Mirror, Signal, Outmanoeuvre
    Apr 2008
    Bracknell, Berks
    630
    Exclamation Indicator stork removal
    Can anyone give me any advice on fitting a new indicator stork on my b5? Any hints or tips at removing steering wheel etc would be cool, it'll save me spending any more hours on it that are needed
    thanks
    White B5 1.8 turbo sport
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    hi its stalk not stork... lol
    anyway not excatly what you want but should point you in the right direction
    Linky
    HTH
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    CraigG's Avatar
    May 2008
    188
    Basically you remove the airbag, then the wheel, then there are two bolts that run thru the stalk holding it (and i think the cowling) on.
    Be sure not to move the contact ring when you remove the wheel, if it doesnt go back on in the same orientation you will likely break the coil inside it when you steer.
    Imola S4 - Bilstein B6 + Eibach Prokit, Anthracite BBS Pescara 18x7.5"
