Badger5Monster Motorsport
Results 1 to 10 of 10
    Jul 2008
    Birmingham
    629
    Boost gauge centre vent install?
    I've bought a 52mm boost gauge which I planned on fitting in the centre or driver-side vent tomorrow. However... stupid question time... what is stopping the installed gauge from rocking up and down as the vent pivots?
    A4 1.8TQS
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,850
    It should be quite tight and I never had an issue with my old vent gauge.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    I've recently installed an oil pressure guage, and found that the guage was deep enough to reach quite far back into the apature meaning it would only move a few mm's up and down.
    I put some sticky foam pads above and below the housing to hold it tight so it doesnt move at all now.
    I did have to remove the flap that controls the airflow though, as the guage hits it. So i put duck tape over the rear of the housing so the air wouldnt blow past the guage constantly.
    TD5 Land Rover Defender build
    Jul 2008
    Birmingham
    629
    I forgot to mention that it's a universal gauge and I'm going to "modify" the existing vent.
    A4 1.8TQS
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,850
    Thats what I did.
    "Stick a V8 in it!"
    15,370
    same!
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    I ziptied the wires going into the back of the gauge to the vent housing. That keeps it pretty secure.
    I did fit one of those in-vent Ambi-Pur air fresheners a while ago which was quite heavy. Just got a small piece of black cardboard, folded it and wedged it in on the underside of the vent which holds it solid.
    Mo power, mo problems
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    This is my next mod too... going to retro-fit the boost gauge I have in the centre vent.
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    Jul 2008
    Birmingham
    629
    My boost gauge came but I have a question! I heard the fusebox is the best place to wire it up but they gave me a very generous wire length of around 0.25m so there's no way it will reach from the centre vents.
    Rather than extending the wire, where else can I splice into? The three wires go to:
    - 12v ignition switch
    - Vehicle ground
    - 12v dash lighting
    A4 1.8TQS
    Feb 2007
    Liverpool
    1,693
    Do you not have any other wire lying about? I had to extend the wiring that came on mine to reach the dash terminals (switched live).
