JMB RetrofitsAH Fabrications
Results 1 to 9 of 9
Thread: n75??
    monteiro's Avatar
    A6 Avant 1.8T Sport Stage1
    Apr 2009
    Kingston
    n75??
    Hi i have my car remap and i think i need a new n75, can I use a n75j on my K03 ??
    Is it safe??
    Thank’s
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    You would have been better off replacing the N75 before you got a remap.
    Mo power, mo problems
    monteiro's Avatar
    Apr 2009
    Kingston
    I not sure if i need to replace the n75 or the DV valve i have log in to the vag.com and came this:
    17963 - Charge Pressure: Maximum Limit Exceeded
    It was runing well before went in to limp mode for 3 minutes then went back to normal
    I was driven at 50 mph
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    I have both a perfectly working N75 valve (in fact I have two)... and an atmospheric adjustable dump valve if you're interested.
    NEW 6 cylinder 40mm front springs - ÂŁ40
    PM me for more info
    monteiro's Avatar
    Apr 2009
    Kingston
    the car has only be remap once i have log with the vag and din't came with any faulty codes, but i may need to replace the dv valve because im using the OEM one .
    thanks any way for the help
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,325
    Could just be a bad map, who did it?
    I wouldnt fit an N75J unless the map is designed for it, although a new N75 might be useful if its overboosting just to rule it out.
    1997 S4 - PPC ÂŁ999 Challenge Track Car Build
    TD5 Land Rover Defender build
    monteiro's Avatar
    Apr 2009
    Kingston
    so far so good no more faulty codes the car was remap by ecu-evolution the map is a good map, will it be ok to fit a n75j will the standart k03??
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,512
    The J valve can cause boost spikes that cause limp mode. It is commom to map the car without the J valve and fit that afterwards to possibly increase the boost slightly. The boost comes in harder and spikes higher,but drops off quicker. I didint like the feel of it and went back to an F valve, suited the map better.
    Is your car DBW? or does she have a throttle cable?
    monteiro's Avatar
    Apr 2009
    Kingston
    Quote Originally Posted by Byzan A4 View Post
    my car is DBW its fine now but im going to replace the DV valve any way
