Monster MotorsportVolks Autos
Results 1 to 10 of 10
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Facelift rear lights?
    Looking at fitting some facelift rear lights on the Quattro, but want to know if there is a difference in look from the pattern type unit compared to oem Audi?
    Price differs obviously, e.g 30 per side on the bay
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=300308369927
    And these go up to 130 for a pair, imagine to be oem units?
    http://cgi.ebay.co.uk/ws/eBayISAPI.d...m=300094439670
    Does the difference in price justify them in anyway?
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,917
    From my experience yes the extra cost is justified.
    I got a set of pattern ones for mine and they bolted up well enough but when fitting the colour coded plastic strips they just would not sit straight and the car just looked like it had been rear ended as the trim was all wavey.
    I got my OEM facelift tail lights from a breaker for 50 the pair. Very pleased.
    Life begins at 140mph
    www.passionford.com
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    did you want used or new
    a used one here on ebay
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    Cheers for info, thought it was just the Lexus type stuff people had trouble with plastics fitting on.
    Preferebly looking for new, but would take very good 2nd hand pair also, as will need to change some wiring aswell i think anyway?
    Jun 2009
    Quote Originally Posted by Oranoco View Post
    I agree completely...while on occasion I get lucky buying discounted parts, I do notice that when buying the more expensive parts, I have less issues when installing and getting them to work properly.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,917
    Quote Originally Posted by Foxmeister View Post
    What type of tail lights do you have at the moment?
    These
    Or these
    If it's the former you will need bulb holders as well but I beleive they plug straight into the old loom and will then require a pin swap on the plug. If you have the later ones you can reuse your existing bulb holders and need to perform the pin swap. if youwant to perform th edual rear foglight mod you will need the 99> bulb holders as well as the earlier ones are missing the electrical contact.
    Pin swaps are;
    O/S - Swap Blue/Red with Black/Green
    N/S - Swap Blue/Red with Black/White
    HTH, I think mine looks loads fresher with the late lights on.
    www.passionford.com
    Foxmeister's Avatar
    Fired Up!
    Funky Pong Champion
    Apr 2009
    Sunny Glesga!
    1,767
    I have the pre facelift type now, same as u had on yours, not the really early type. So need to swap some pins just. Cheers.
    May 2009
    32
    hi ive just bought some of the rear lights in the 2nd picture and one's of the car, do these need the pin swap ? they came with the bulb holders They are from a 2000 Audi A4 B5
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    2,917
    If you're changing to 99> tail lights you will need to perform the pin swap as per above. It's not too bad just a little fiddly
    www.passionford.com
    May 2009
    32
    ok thanks sorted it out now !! cheers
