Results 1 to 12 of 12
Thread: ABS UNIT/ECU
    May 2009
    32
    ABS UNIT/ECU
    hi i'm after a 2nd hand abs unit/ecu but the ones ive seen are a different number to the one on my car my part number is 8EO614111A but all the others iv'e looked at have another letter on the end for instance 8EO614111AM does anyone no if this unit will work on my car ?? cheers ginna
    dieselfitter251's Avatar
    Blow ma own trumpet?
    Jun 2007
    High 'C's
    1,130
    Hey man. Search the forums for all the related info but I'm guessing you've got quattro, probably with EDL. You need an 8E0614111A or 8E0614111E, (I think). The unit may ben repairable yourself, (again check the forum) but check out bba-reman they'll do you a fix for about 100. If it's unfixable they'll sort you out with a recon unit.
    You got any fault codes or symptons?
    Ford Mondeo 2.0i Durtec Ghia X Estate
    Leather / Dog Hair.
    Dieselfitter 251
    A4 avant '97 1.9tdi q
    a.k.a. STINKY
    [B]250k!
    ..she's gooooonnnne!!!!
    May 2009
    32
    hi iv'e checked the forum for related issue's as i was getting the big flashin exclamation mark and the abs light on. i found a repair for the abs ecu which i did and the wire was broken so repaired that and the big red light goes off and just flashes every now and again ive scanned with vag-com and it's sayin nsf wheel speed sensor just got to change that and re-check everything i thought the intermittant big red flash is still meaning the ecu is still dodgy !! yes iv'e got a 2.8 quattro 30v, what's edl ?? cheers for the reply dieselfitter
    Jun 2007
    High 'C's
    1,130
    Potentially still your ecu but change the sensor. It's still the cheaper option. Good luck!
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,391
    if it detects a faulty wheel sensor you'll get the big (!)
    If its an ECU fault it usually brings the (!) up as soon as you start the car.
    TD5 Land Rover Defender build
    May 2009
    32
    right well the big red (!) isn't on when starting just the abs light then sometimes the big red (!) appears for a little while then goe's..
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    mine done this. i fixed the wire but think i broke something else. i got no (!) but the abs light was on all the time.
    May 2009
    32
    ian have you scanned it with vag com ? mine has come up with nsf abs sensor fault !! gonna try it and see what happens !
    May 2008
    perth
    1,197
    i did at the time.think it said driver side front on mine but it was the module that was shot.
    May 2009
    32
    ah right ! did you buy a new one or send it to bba reman ? ?
    May 2008
    perth
    1,197
    bought a working secondhand one.
    May 2009
    32
    ok mate cheers !
