AH FabricationsJMB Retrofits
Results 1 to 7 of 7
    Mar 2004
    15
    possible maf sensor fault........ pls help
    i have a power problem with my 2000 1.8t and hope someone can shed some light on it.
    it is lumpy at idle , it's holding back on aceleration and is jerky when i come off the throttle it seems to speed up as i lessen the throttle opening.
    i have it booked in for a fault code test on tuesday with a local audi specialist ,is this likley to pick up a maf sensor fault or am i wasting 40.
    typicaly the car is for sale at the moment and i dont want to put off potenial buyers i need to get it sorted asap.if anyone can confirm the maf sensor is at fault i may just go buy one and cancel the diagnostics appointment.
    any help would be great
    thanks
    Mar 2004
    15
    Re: possible maf sensor fault........ pls help
    im in essex...think that might be a bit of a trek.
    but thanks for the offer
    Dec 2005
    united kingdom
    9
    My car has a similar problem can you tell me what you did please this is driving me crazy. Thanks
    John (e-mail john@cram35.freeserve.co.uk)
    jcb
    Sep 2005
    uk
    4,077
    any modifications? changes to filter?
    CraigM's Avatar
    Apr 2004
    Scotland, UK
    98
    My A3 1.8t used to do that and I managed to cure it by cleaning the MAF sensor with isopropyl alcohol - also known as electrical cleaning solvent - you can get it at Maplin.
    Worth a try if you haven't already cleaned it.
    This is the bit you want to clean:
    http://www.mcmillan-uk.com/clio/MAF01.jpg
    http://www.mcmillan-uk.com/clio/MAF02.jpg
    Dec 2005
    united kingdom
    9
    Thanks guys will try that but also noticed now that on occasions the brakes are hard to push as if the servo wasn ot working properly. This is an intermittant fault just wonder if it is related
    imported_VaulterTim
    Try checking your vacuum hoses on the inlet manifold etc., you may have a leak somewhere...
