Volks AutosChris Nott
Results 1 to 20 of 20
    Izzy1's Avatar
    Vorsprung Durch Technik
    Sep 2008
    Birmingham, UK
    348
    New key needs programming...
    Hi All,
    My old key fob stopped working and when i opened it up a small chip had come loose off the circuit board.
    I have since brought a new fob of ebay and was wondering how I can get this programmed to my car so it works?
    Is it a dealer job?
    cheers
    p.s This is the only key i have.
    Izzy
    Bora TDI sport
    Audi A4 TDI
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,379
    Is it just the remote that needs programmed?
    Does the key start the car?
    TD5 Land Rover Defender build
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    yup just the remote. key starts car fine.
    Izzy
    Bora TDI sport
    Audi A4 TDI
    "Stick a V8 in it!"
    15,379
    You got the full version of VAGCOM? If so you just need to follow the instructions on rosstechs page for programming new fobs. If not, you'll need to find someone with the full version.
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    i have the fully version. is it the remote matching that i need to try? if so i'll give it a shot tonight
    Izzy
    Bora TDI sport
    Audi A4 TDI
    "Stick a V8 in it!"
    15,379
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    will try tonight and let you know if i was successful.
    Izzy
    Bora TDI sport
    Audi A4 TDI
    Feb 2009
    Wiltshire
    97
    I got a new remote not long after getting my car, i didnt need to use VAGcom to match it to the car. If i remember rightly I put my non remote key in the ignition and turned it on but didnt start the car.
    Then got out the car and locked the door with the new key whilst holding the lock button then unlocked the door whilst holding down the unlock button.
    I then removed the key from the ignition and shut the door and used my new remote to lock/unlock the doors. All worked fine.
    Not sure where i read that all from originally but will have a look to see if i still have a link.
    SOLD :: Ming Blue 99' 2.8 Quattro Avant :: Mats, boot liner and spare wheel for sale.
    Now Looking for a decent A4 Avant diesel for less than 1600
    "Stick a V8 in it!"
    15,379
    he only has one key...
    Although if he was to split it, and use the remote part outside that might work.
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    would i need to cut a new key for this?
    Izzy
    Bora TDI sport
    Audi A4 TDI
    "Stick a V8 in it!"
    15,379
    did you try using vagcom?
    You probably should invest in another key anyway, but that doesnt explain why vagcom cant program the remote properly...
    Can you give me the "software Coding" and "part number" values from the central locking module?
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    no didn't get a chance. but will defo do it tonight now that my laptop is fully charged.
    "Can you give me the "software Coding" and "part number" values from the central locking module?"
    where do i get this from?
    Izzy
    Bora TDI sport
    Audi A4 TDI
    "Stick a V8 in it!"
    15,379
    they're on the vagcom interface when you open the controller iirc.
    You've had problems with it before, so i want to confirm the coding and part numbers are correct!
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    yup i have. i'll have a check when i get home and see if i can find it.
    Izzy
    Bora TDI sport
    Audi A4 TDI
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    just had a look on vag com and the below method does not work. i cannot select 3 and set to go.
    also looked at the software code in central locking and it's 15178 and think your after the vag number which is 8D0 682 257 E let me know if this is correct. if not i'll have another look. more details may be needed as i'm a newbie to vagcom and don't really know what i'm doind. lol
    thanks again for your help.
    Izzy
    Bora TDI sport
    Audi A4 TDI
    "Stick a V8 in it!"
    15,379
    http://www.ross-tech.com/vag-com/car...-matching.html
    Try the first set of instructions on there then?
    Coding looks fine for having remote locking and the part number is remote capable.
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    just tried the remote matching proceadure and it stores the test value and even lets me ok to save but for some reason it deletes it again.
    any ideas on what could be going on? could it be the vag cable? it's one i brought of ebay for a few quid...
    Izzy
    Bora TDI sport
    Audi A4 TDI
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    bump
    Izzy
    Bora TDI sport
    Audi A4 TDI
    "Stick a V8 in it!"
    15,379
    really not sure whats going on.
    I've never tried these procedures myself, but ive never heard of any issues before.
    Either theres something wrong with the way your doing it, or your softwares being a bit flakey.
    Might be worth taking it to someone thats done it before to try and work out whats going on, or let the dealer fix it.
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    i'll give the dealer a call and let them charge me around 45 to fix. just hope they don't add on hidden charges.
    thanks for you help.
    Izzy
    Bora TDI sport
    Audi A4 TDI
