Badger5Volks Autos
    A4Chris's Avatar
    Mar 2008
    Fife
    1.8T Sport - rear roll bar / suspension issues??
    I've started getting a clatter / rattle from the rear end when driving over bumps. This has coincided with the car feeling 'floaty' on the motorway (used to feel absolutely planted). Also, as a test, I tried an emergency stop from 60 and was a bit shocked to feel the rear end of the car skew from left to right.
    It's booked into the garage next week for a look but I was just wondering if you guys know of any possible causes? Could it be a problem with the rear roll bar?
    Chris
    A4Chris
    B5 Audi A4 1.8T Sport (standard)
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    is she not quattro? If not there is no Anti roll bar to worry about, so its probably a blwon shock TBH. Had it happen myself. Take a look at the shocks from the back of the car and see if there is visable oilage on them. Or i suppose it's possible the axle bushes have disintergrated, that too can happen, but tend to deteriorate with age
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,388
    Possilby the rear top mounts?
    TD5 Land Rover Defender build
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Sounds like either rear top mounts or more than likely the rear shocks. Would be wise to swap both, though I've been told by an Audi technician that due to the way they are constructed, rear top mounts rarely fail... but as you'll be whipping it all out, you might as well stick new ones in.
    To be honest though, I'd not waste your money taking it to a garage... the rear shocks are relatively easy to replace yourself if you're fairly handy with the spanners.
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    A4Chris's Avatar
    Mar 2008
    Fife
    Thanks guys.
    Sounds like rear shocks may be the issue then. I'll have a crawl around under the car tonight and see what I can see.
    If it is shocks will probably do myself over a weekend (seized rusty bolts galore??).
    A4Chris
