Volks AutosAH Fabrications
    Apr 2009
    89
    Question Brake lights don't work till pedal about 1/3 way down! (brake light switch maybe?)
    As per the topic title, my brake lights won't come on until the pedal's about 1/3 of the way down - i.e. after the car has started braking.
    I'm guessing it's a brake light switch issue - Do these cars have adjustable switches or is it a case of replacement?
    Mine's a 'W' reg, 2000, A4 (B5 model) 1.9TDI 115hp Saloon.
    If it is the switch, is it a DIY replacement job, how easy/hard?
    (complete audi novice so please go easy!)
    Impster
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,372
    Its simple enough to change, you need to drop the drivers knee bolster and thats only 4 8mm headed bolts, that will allow access to the switch. You can remove the wire to the footwell light to remove the bolster completely. Once in there you will know whether its loose or needs changing
    Apr 2009
    89
    Top man. Thanks for the info. Once this bloody rain eases off I'll take a peek.
    Where's a good place to get a replacement if I need one - local VAG dealer or are there better options?
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    dont know about yours but mine is adjustable , screw type think its above the clutch pedal
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    Mine needs doing too... I have a similar problem, though not quite as severe!
    NEW 6 cylinder 40mm front springs - £40
    PM me for more info
    Apr 2009
    89
    Does anyone know what kind of switch mine's likely to have (yr 2000, 'W' reg 1.9 TDi 115hp Saloon)
    If it's adjustable, I presume it's a 'two-nut' on a thread affair - similar idea to adustable handbrake/clutch cable concept? Is there a way of finding out without dismantling?
    Many thanks for all the help - greatly appreciated.
