Monster MotorsportVolks Autos
Results 1 to 24 of 24
    dieselfitter251's Avatar
    Blow ma own trumpet?
    Jun 2007
    High 'C's
    1,130
    Torque settings for rear CVJ fix...
    Anybody any ideas where I can get torque settings and what needs to be torqued? TA!
    Ford Mondeo 2.0i Durtec Ghia X Estate
    Leather / Dog Hair.
    Dieselfitter 251
    A4 avant '97 1.9tdi q
    a.k.a. STINKY
    [B]250k!
    ..she's gooooonnnne!!!!
    jcb
    Sep 2005
    uk
    4,077
    if it is an outer cv boot fix then the hub bolt is the only thing (other than the upper and lower suspension arm bolts.
    but the hub bolt needs the torque
    60ftlbs iirc
    Jun 2007
    High 'C's
    1,130
    Cool. Putting a new CVJ on. Was going to remove the whole drive shaft for easy access. Anything else that may need horsed up?!
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    i suspect the rear hub nut will need to go much higher than 60lbft...
    the fronts go to something like 190lbft then angle tightened a further 120degrees or so
    everything else i just suggest the tight setting
    TD5 Land Rover Defender build
    Jun 2007
    High 'C's
    1,130
    Alright, I may bend Audi Edinburghs ears on this or go with the front hub torque setting. Am I right in think that once the drive shaft is released from the diff and the hub nut undone, the drive shaft should 'just come out' ....
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    Oct 2007
    2,597
    I torque up CV joint central bolts to 230lbs, and nuts to 250.
    "Stick a V8 in it!"
    15,389
    yep, ive not looked to closely at the rear diff, but if the CV bolts on, then simply unbolting it from the diff and pulling it out the hub should work once you've undone the bolt/nut, you should hopefully manage to get it out without having to touch the suspension arms. If its not bolt on, then you will probably have to undo the upper or lower link on the suspension to get enough room to pull the flange out the diff.
    You will need someone to stand on the brakes while you undo the nut, and you will need to leave some wheel bolts in to stop the disk spinning on the hub. You might be able to do it with the car on the ground and the little centre cap off the wheel to make it easier to loosen.
    jcb
    Sep 2005
    uk
    4,077
    Quote Originally Posted by jcb View Post
    60ftlbs iirc
    didn't think that was right!
    got to do my rear wheel bearings this weekend!
    Jun 2007
    High 'C's
    1,130
    ^^^good luck.... The teabag ended up dropped off at a garage due to various siezed bits when I tried the wheel bearings...
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    jcb
    Sep 2005
    uk
    4,077
    oh great!
    thanks for that
    Jun 2007
    High 'C's
    1,130
    I'm sure you'll be fine.... I get the fear about breaking things!!!!! Oh, and I think some of the nuts and bolts haven't been off in around 200K! I'd be siezed too!
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    jcb
    Sep 2005
    uk
    4,077
    ah well that is where i have some confidence.
    uprights have never been on longer than about a year as I have had poly bushes, coilovers, driveshafts and brakes all done over the years.
    they have been on and off so many times I am surprised they haven't become so loose the have fallen off! [think positive]
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    I hear ya, mine are velcro'd on now,lol
    Hope the garage doesnt fleece you too much Dieselfitter251
    jcb
    Sep 2005
    uk
    4,077
    i am doing the bearings while he does the clutch. at least that is the idea!
    Jun 2007
    High 'C's
    1,130
    Quote Originally Posted by Byzan A4 View Post
    I've been through enough of that to think all garages are sheep farmers! But I'm very careful now... and more willing to get stuck in myself. Local garage is only doing the front right upper rear arm, as I can't be arsed with the pinch bolt etc.. and I'm not to familiar with struts etc....
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    "Stick a V8 in it!"
    15,389
    You only become familiar with it by getting stuck in
    Jun 2007
    High 'C's
    1,130
    How true, I hang my head in shame! Like I said.. I get the fear! Probably not a worthy excuse tho.. I'm willing to get the CVJ done myself, we'll see how I progress from there..
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    jcb
    Sep 2005
    uk
    4,077
    You only become familiar bloodied, angry, on first name terms with Halfords staff, a haynes manual expert and pissed off with it by getting stuck in
    true
    "Stick a V8 in it!"
    15,389
    lol
    I find it satisfying once it all goes back together and you think "i just saved myself 300quid" however ye, it can be frustrating at times.
    Unlike my previous cars however, and barring the old favourite pinch bolt on the front suspension, i've found stuff on this car has all come apart pretty easily. Something i attribute to german engineering :P
    Jun 2007
    High 'C's
    1,130
    Doing the CVJ tomorrow. I'll let you know how I get or don't get on!
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    jcb
    Sep 2005
    uk
    4,077
    i like the cash saving element, I just hate the "******! where am I going to find one of those on a Sunday!?" feelings!
    Like when you have just sheared an enclosed end sub frame mount bolt on a Mk2 Golf you are close to finishing restoring and need to get it to the MOT centre!! its a floor chopping remedy!
    Jun 2007
    High 'C's
    1,130
    Utter failure. I hang my head in shame. Managed to get the hub dropped and then had no way of gettingthe CVJ off so we continued to undo the driveshaft from the diff but that wouldn't budge.... Is the inner CVJ supposed to come away from the diff easily enough when the bolts are undone? Anyway it was solid. Working on the deck with just an axle stand so we were out of leverage too. Considered knocking the diff end of the shaft but though that would only damage the inner CVJ and or diff seals.
    I leave myself at the mercy of the forum but would appreciate any info on where we went wrong. My dad's been working on cars for over fifty years and he was stuck too, I'm wondering if the inner part of the drive shaft is siezed on some how due to the teabags moon mileage.?
    Answers on a postcard or as none of you have my address leave me a reply.
    Incidently. Audi said the torque for the hub bolt is 115nm + 180o turn...
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    "Stick a V8 in it!"
    15,389
    I've never seen the rear diff flanges, but the front ones dont have anything to locate the CV other than the bolts, so the joint should just come apart once you've removed the fixings. Might need a little persuasion if its never been off though?
    You did remove all the bolts didnt you? :P
    I spend nearly an hour beating lumps out of a transit hub/brake disk once, trying to get them apart. Then noticed, removed the bolts and it came off in 3 whacks lol.
    Jun 2007
    High 'C's
    1,130
    Aye bolts were removed. If I had more access i.e. a lift or pit I'd try adding heating or a bit more force with a hammer. Need's it's MOT though so it's in to the garage, preston and Dublin next weekend!
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
