Badger5Volks Autos
Results 1 to 14 of 14
    Mar 2009
    53
    elusive fuel filter
    where the hell is the fuel filter on an audi a4 1.6 1995?!
    iv never owned an audi before and i cant find any pictures or guides anywhere!!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,318
    never looked myself but i'm going to guess its gonna be on the side of the fuel tank just infront of the offside wheel
    TD5 Land Rover Defender build
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    It is, jubilee clipped alongside the tank
    Mar 2009
    53
    right got it, replaced it after a battle with a seized jubilee clip, i was hoping the new filter would be the cure to my problem but no shes stillhaving problems starting and still pottering when idling and jerking when accelerating =/, any ideas?
    Apr 2004
    12,505
    Right, i would try openeing the fuel filler cap next time its pottering to see if that cures it, if it does and wooshes when you open it, the N80 vavle is suspect. A quick thought occurs, have you read the fault codes off her yet?
    Mar 2009
    53
    nah i havent got the kit for that =/
    Mar 2009
    53
    anyone live in or near the west midlands and fancy checking my car for fault codes?
    Jun 2003
    World of my own
    9,813
    If all the normal things are OK - plugs etc then is the temp running OK? Could be a faulty temp sender which is a common fault on the B5 and gives all sorts of wierd problems as the ECU thinks the engine is hot when it's cold and/or vice versa. This causes lumpy idle, stalling and bad starting. It's a 20 part from the dealer and an easy DIY fit, so worth looking at.
    Alex Turner
    Mar 2009
    53
    yea i replaced the plugs, fuel filter, air filter and even put a quater bottle of redex in the tank but its only eased the problem. the temp gauge hardly ever moves, never seen get even close to half way.
    "Stick a V8 in it!"
    15,318
    There lies your problem then!
    The temp guage has a buffer which means that at the normal operating range it will display 90. This means at any temp from about 75 to 105 it sits pointing at 90, and only moves if the temp exceeds this range.
    If its not getting to 90 then either the sensors shot, or the thermostat is jammed open. Our 1.8T had a jammed thermostat when we baught it, and it would only ever get to 90 if it was left idling in a traffic jam or something, as soon as you were moving it would drop right off.
    If yours isnt even doing that then i'd look at the temperature sender first.
    olds_kool's Avatar
    Jul 2007
    stoke on trent
    1,071
    Quote Originally Posted by Rutter View Post
    im in burslem, staffordshire if thats any good to you
    kev
    a4 stuff http://shop.ebay.co.uk/merchant/olds_kool_gti
    99 1.8tqs black saloon
    99 1.8tqs grey avant
    90 eunos roadster
    Mar 2009
    53
    ahh nice one! are they easy to fit or will it be a garage job?
    Mar 2009
    53
    i may have to drop by yours at some point then if you dont mind xD
    Jun 2003
    World of my own
    9,813
    Easy to fit yourself. Make sure the coolant isn't hot as some will spray out when you remove the sender. Release the pressure in the coolant system by undoing the cap on the reservoir, but make sure you put it straight back on. Then locate the sender, unplug it and then slide out the retaining clip to remove. It might take a struggle to get it out if it's the original (old style ones are blue). Replace it using the new green version from dealer with a new O ring. Have the new one ready to go when you pull the old one out to reduce coolant loss. Slide the clip back in and reattach the wiring.
    Don't use cheaper ebay ones, get one from a VAG dealer - they're only 20.
    Alex Turner
