Smoke coming out of the engine :(
Nez
Member
It's my birthday
London
Website
peace.netfreehost.com
Hi all just need some help guys :( today after check the oil and water on the car I open the boot and I saw a little smoke coming from the corner of the engine where is the turbo house on left side and then after few min's it stopped and then again it started :(
There is no error code and engine runs fine with no problem so what it could be guys anyone had this problem with their car ?
Here is the picture and I mark it where the smoke coming from :(
could be a rocker cover gasket gone, mine was the same until i changed the seal and now all is cool. try seeing if you have any oil leaking
Camshaft chain tensioner leak?
is replacing the tensioner a cam-out job? as my chains make a noise some mornings for a moment when i first start it up. i presume whilst the tensioner pressurises.
2nd that. The smell should be fairly obvious if it is oil leaking and dripping onto the turbo.
I checked for oil leak but found nothing but there is oil burn smell :( and I also I washed the part where it was smoke with water and now it stopped :uhm:
My engine bay stunk of burning oil the first night I drove it home. Turns out the guys in the workshop had filled the oil from a watering can without a funnel none too accurately.
Well, the camBELT tensioner does not have a gasket. I guess they de-tensioned the
belt, did the gaskets on the cam tensioners (mechanical devices to adjust cam position
- S4 has VVC) and rocker cover, then put on a new belt and belt tensioner. The reason
I commented was that new mechanical tensioners are about 300 quid each. You still got
a good deal at that price if they replaced the cambelt.
What I have in the invoice are these:
Timing Belt Kit
Water Pump
Auxillery Belt
Auxillery Tensioner
Anti Freeze
Tensioner House
All that for £370 :)
Yep, belt tensioners. That is still an absolute bargain though.
