Chris NottBadger5
    imported_absautos
    newbie dash fault pls help!
    hi all, i have a '98 a4 1.6 and the disply section of the dash(where it shows the multi function display, radio stations etc) sometimes dont work i know it can be switched on and off via the wiper switch but it still dnt work [img]/ubbthreads/images/graemlins/confused.gif[/img]
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,700
    Re: newbie dash fault pls help!
    Is it completely dead or just faded? These units are notorious for fading. Mine does it from time to time (well, quite a lot of the time, actually).
    There's no known cure other that complete replacement which is expensive. I've seen upwards of 400 quoted before now.
    Jun 2004
    Toronto, Ontario
    Mine fades as well around the edges, and it seems to do it when it gets hot outside or in the car.
    imported_absautos
    mine was dead when i bought it, then it decided to work perfectly for about a week and i havnt seen it working since.
    jdp1962's Avatar
    Grumpy Old Man
    May 2003
    5,700
    [ QUOTE ]
    [/ QUOTE ]
    That sounds more like a wiring fault. Have you tested the circuit, & all the connections etc?
    imported_absautos
    have checked the connections behind the radio thats all so far, thought it may be the wiper switch any ideas? [img]/ubbthreads/images/graemlins/idea.gif[/img]
