EM TuningAH Fabrications
Results 1 to 7 of 7
    the matrix is comin
    Jan 2009
    ramsgate
    147
    learnt at a price
    when changin a turbo on the car i strongly reconmend you change the oil line to an from the turbo. i found this out at a cost to me when the new one went the same way as the old one
    built in germany caressed and loved in england.
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Indeed. I was told oil starvation is the number one killer of turbos.
    Mo power, mo problems
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    i may get new lines then.i need to take the turbo off to change the housing anyway. any idea how much they are?
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,522
    About 60 iirc for the feed, the return line will be fine. I aquired a used feed line and soaked it in carb cleaner and flushed it to ensure it was clear.
    Sorry you had problems matey
    the matrix is comin
    Jan 2009
    ramsgate
    147
    thanks mark for that just a good job it wasn't one from audi or a recon one. just need to find another one siena's one wasn't good to much play they said. not sure if i can get one from a a3 an just change the turbo casing for the inlet from the air box to make it fit.
    Apr 2004
    12,522
    Nah the compessor housing needs to be changed and thats a heat up and press off job. Also the exhaust housing is different mate. You need one from an A4,A6 or Passat AEB Or AJL or at a push APU engined car. Although the numbers will vary on a non tuned car it will be fine IMHO
    Apr 2004
    12,522
    Stuart, i will willingly pay carriage to collect the old units from you if they only due to be skipped as my tuner in polands wants some to "play" with his new lathe.
    Let me know I tried to PM but they don't seem to be working at the mo
