EM TuningChris Nott
    imported_bpascua
    Clutch bite point - can it be changed on a 96 A4?
    Hello,
    I just bought a A4 1.8T (96) and the clutch bite point is irritatingly high - can this be lowered? if so is it an relatively straight forward operation for a mechanic?
    Many Thanks
    Brian
    Jul 2004
    Minnesota, USA
    42
    Re: Clutch bite point - can it be changed on a 96 A4?
    Unfortuneately, it can't, that I know of. It's, as far as I know, a sealed hydraulic clutch. It MAY be a sign of a wearing clutch, but some just bite high. You can ask a mechanic, but I'm quite sure it can't be changed.
    imported_bpascua
    Bugger - the cars done 74k can it have worn through the clutch already?
    Brian
    madkebab's Avatar
    Dec 2003
    South West
    396
    This is a common trait of the A4, mine has done 77k and bites really high but does not slip. After a while you get used to it.
    Jul 2004
    Minnesota, USA
    42
    Before buying my A4, we test drove one, with a real high bite point. The clutch had been checked out, and only showed minor wear, just a trait of that particular Audi. Personally, mine has a rather low catch point. It's something you have to get used to, because all cars will have a different catch point.
