EM TuningVolks Autos
Results 1 to 14 of 14
    aidank1981's Avatar
    Nov 2006
    Shetland Islands
    251
    Any drawbacks to a wider rear on a quattro?
    hey all!
    in the market for some 18's for the s4.... had 35 profile 19's on the s3 an thought it was a bit of a hard ride so thought i'd scale down!
    i like nouvalari's/original B5 rs4's but both maybe too commen (an had them on s3), LOVE MTM bimoto's but too pricey just now, fancy BBS CH's but maybe too jap....
    anyway main question is i do fancy a wider rear option ie a BMW type set up, i understand the quattro system is front bias so they'll be no Advantage but will there be any disadvantage other than tyre cost an not being able to rotate my tyres??
    not many seem to provide wider rear options for not BMW style rims, anyone found different?
    just to clarify is it a higher offset to push the wheels out from the arches or a lower one? ie offset is dist between hub face and alloy face right?
    thanks again
    Audi S4 Black on Black. 1999(T)facelift, Aluminium Mirrors, KW Varient 3 coilovers, AmD remap, uprated D/V's, 315bhp375Lb/ft torque, milltek down, 100cpsi cats an back, S4 B6 18" Oem runnin toyo T1-R's. Rs4 B5 front brakes still to fit...
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    A higher offset brings the wheels further inboard. If you get wheels with a high offset, you can always fit spacers behind them.
    Why do you want wider rear wheels? Could that not cause problems with the 4WD as the rolling resistance on the rear wheels would be higher?
    Mo power, mo problems
    aidank1981's Avatar
    Nov 2006
    Shetland Islands
    251
    ah ha...never get that the right way round!
    reason would be purely asthetic mate, just look's good! reason for post is just down to the fact i wouldnt sacrafice performance for looks hence good suggestions like rolling resistance all welcomed
    any other foreseen problems?
    Feb 2007
    Liverpool
    1,693
    Spacers are the way to go if you want to fill out the arches. Just make sure you get hubcentric ones if you can.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,372
    It will work, but you need to ensure the tyres rolling radius are basically the same.
    Anything more than 0.5-1% difference and you'll start getting issues with winding up the center diff.
    There really isnt a lot of room on the rear of a quattro anyway, so i'm not quite sure how much of a stagger you will actually manage, unless you go for say 7 or 7.5" fronts and 8 or 8.5" rears, need to be careful with the offset too, especially with wider rims on the rear, you need to use quite a low offset to clear the suspension upright, but that means you start hitting the arches.
    TD5 Land Rover Defender build
    Aug 2007
    111
    Quote Originally Posted by eatdegrub View Post
    I know it doesnt make much difference thought the quattro was 50/50
    "Stick a V8 in it!"
    15,372
    Yep it has a proper centre diff which splits power 50:50, the diff has a torsen centre, so if one axle slips it will shunt the power the other way.
    jcb
    Sep 2005
    uk
    4,077
    nothing a good 4 wheel slide on a wet round about won't free up
    aidank1981's Avatar
    Nov 2006
    Shetland Islands
    251
    so the b5 s4's are a true 50/50 split are they? i know my s3 was front bias but it was a completly different diff set up.... havent had time to road test the s4 too much as yet!
    Aug 2007
    111
    someone will correct me if im wrong, but i always thought if the engine is trans mounted it has a different 4wd system and are front biased but if there longitude they use the torsen system which is 50/50 ?
    Jul 2007
    341
    Quote Originally Posted by mikeya4 View Post
    yea, the A3/golf 4motion etc use a haldex centre diff. which is in normal driving hugely front biased.
    1999 Audi A4 1.8TQS (Standard)
    2003 VW Golf GT TDi
    2002 Audi S8 4.2 SOLD
    2004 Alfa 156 2.4JTD 20V Veloce SOLD
    2000 Audi A4 2.8 Quattro tiptronic (Electric heated seats, winter pack, lowered on H&R Springs & 18" A8 sport wheels) SOLD
    1999 Audi A4 1.9TDI 110hp (with full Audi Sports kit) SOLD
    aidank1981's Avatar
    Nov 2006
    Shetland Islands
    251
    sorry....but ta sumarise then is the B5 S4 quattro's a true 50/50 split then? will have to wait for some snow to test otherwise
    Aug 2007
    111
    yes indeed
    "Stick a V8 in it!"
    15,372
    yes, the S3 haldex system uses a viscous coupling which only really transfers power when there is a speed difference between the front and rear axles, with most of the time it basically being a front wheel drive car.
    All A4 and larger cars use a proper centre diff, with permenant 4wd to all four wheels.
