AH FabricationsEM Tuning
Results 1 to 12 of 12
Thread: S4 Clutch
    EnzoS4's Avatar
    Sep 2005
    UK
    200
    S4 Clutch
    been in for a service and Audi have said the clutch is on its way out. this is the original clutch, so about 8ish yrs old... 100k miles, which I think is great for a clutch but could be why so expensive.
    looking to get this done, but most of the cost if labour and wondering what else is worth doing..? like engine mounts, gearbox mounts.?
    how old is your clutch and if you had it replaced what was the cost.?
    jcb
    Sep 2005
    uk
    4,070
    I would start by removing my car from teh audi forecourt, that will save you about a grand straight away!
    100k is pretty good for the original clutch.
    wouldn't bother with replacing mounts unless they are also knackered or you are driving liek you stole it and want to lose the sloppy sensation
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    how exactly can Mr Audi know the clutch is away....
    I presume its not slipping, as you'd have noticed that, so what is the problem...
    TD5 Land Rover Defender build
    Oct 2007
    2,597
    ^^^ Not all faults to do with clutches are related to slippage though, Aragorn.
    A worn friction disc could cause excessive pedal travel, without slipping, especially if the car's driven with some degree of mechanical sympathy.
    A worn pressure place can cause a change in pedal feel - the pedal could become extremely hard to operate.
    EnzoS4's Avatar
    Sep 2005
    UK
    200
    that's what Audi said the pedal is hard to operate.. I do find 1st some times hard to select.. looks like a new clutch..
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    if your handy with the tools just get a shot of an engine crane and do it yourself. thats what i did. it may be a pain to do but its worth the few hundred quid you save.
    Oct 2007
    2,597
    You may need a new flywheel too.
    EnzoS4's Avatar
    Sep 2005
    UK
    200
    ian52 - I'm ok with the little bits, but wouldn't want to tackle this...
    siena - how would you know, when the gearbox is out...?
    what's included in a clutch kit - the clutch obviously, what about pressure plate.?
    then you have a flywheel.
    "Stick a V8 in it!"
    14,900
    The pressure plate and the release bearing generally come with the clutch kit.
    Not sure how you would check the flywheel, as if its not slipping or juddering it might well be fine.
    Oct 2007
    2,597
    S4 clutch doesn't come as a kit, unfortunately.
    The pressure plate, friction disc and release bearing are all priced individually.
    I'd replace the pressure plate with an RS4 item while you're there.
    I've done the same to an S4 belonging to a member on here, went back together today.
    Oct 2007
    2,597
    I replaced the dual mass flywheel with a single-mass item too. As is common with DM flywheels in turbocharged or higher-power Audi's, the original showed signs of overheating, with prominent hot-spots...
    Old and new...
    New item in place...
    jcb
    Sep 2005
    uk
    4,070
    diy on DM Flywheel inspection
    http://www.dxdracingclutches.com/inspectdmf.html
    TBH unless its new it is probably shagged! they are not great
