EM TuningVolks Autos
Results 1 to 16 of 16
    Mar 2009
    Bethesda, North Wales
    40
    downpipes are off!!!!
    right guys on my quest to find what the hell is wrong with my car, the downpipes are now off to do the piggie pipes + i only have one set of 02 sensors saves relocating the second ones.... other than the obvious turbos (i wish) is there any prone bits to go wrong on the b5 99 model s4 that i could replace
    and does any one know if the coolant temp sensor would put the car into limp mode if it wos reading wrong codes!!!! because my temp gauge shows that the car is runnin at 65 degrees when driving when i belive that it really should be closer to 90,
    this them comes into coincidence that my car weirldy runs boost when the temp rises to 'normal'
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    If your car is reading cool it's either a faulty ECT sensor or a knackered thermostat. Pray it's the ECT sensor!
    Mo power, mo problems
    Mar 2009
    40
    i take the thermostat is a ***** to get at???? and the ECT is located??????
    Mar 2009
    40
    oh by the way its all back together now now, and since i have only got one set of lambda sensors i have no cats and no CEL's wooh hoo but still no boost i will order the engine temp sensor and see what that does grrrr!!!! any one want a swap??? hahahah
    Feb 2007
    Liverpool
    1,691
    The thermostat is usually one of the things to do when you're doing a cambelt change.
    The ECT sensor is a black or green sensor (depending on what year your car is) on a black flexi coolant tube underneath the accordian hose. Remove your y-pipe, accordian hose and airbox to get access. The sensors can get really stuck, so try something like WD40 to free it up a bit. Mole grips are your friend at this point!
    Feb 2007
    Liverpool
    1,691
    Did you check your turbo shafts for any play whilst you had your downpipes off?
    Mar 2009
    40
    no for some daft reason but with runnin it with a foot and a half of downpipes (noisy as fook) the whistle spooling up sounds beautiful and smooth but there is just no go, soon as i ahve money in the bank i will buy this sensor and let you know how i get on
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,943
    I doubt the CTS would cause no boost, are there no codes for the N75 etc?
    TD5 Land Rover Defender build
    Feb 2007
    Liverpool
    1,691
    Could be a massive boost leak if you were able to hear the turbos spool up cleanly with ths DP's off (ie: sounds like the turbos are working fine). This will throw the car into limp mode.
    Ideally you want to pressure test it. It may seem like a bit of a trek, but i'd highly recommend going to www.Unit20.org on the Wirral for a proper health check. Grizz will be able to give your car a good going over and will be able to advise on and supply any parts which might need replacing, ie: DV's, TBB, etc.
    stapo69's Avatar
    All hail the mighty quattro!
    Mar 2007
    966
    The thermostat is a long pain in the arse job, trust me!
    MRC-Powerflex-Hotchkis-Porsche-Compomtive-Vredestein-034-JHM-Apikol-EBC-FK-Labree-Vibrant-Recaro
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    i just replaced my temp sensor and it was blue 4 pin square it was like 11.50
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    IANS4's Avatar
    The Fiend!
    Feb 2009
    Co.Antrim N.Ireland
    16
    It could be the Y shaped rubber boot where the turbo pipes meet the TB m8, very prone to cracking and easily changed. Mine went a few monts ago, lost all boost it turns out a new one is only about 15 quid from audi.
    Hope you get sorted soon
    Mar 2009
    40
    right all pipes have been pulled off, checked with a fine eye, put back on with care, and the n75 ha been changed, the maf has been changed and the o2 sensor that showed faulty has been changed,
    but what i am going to do is just order a set of hoses as well as an intercooler and take it from there...... how prone to splitting is the intercoolers????
    Oct 2007
    2,597
    With stock boost pressures, I haven't come across S4 intercoolers split.
    Feb 2007
    Liverpool
    1,691
    There are plastic end caps on the stock intercoolers which can crack.
    Rather than fork out a few hundred on all that stuff, wouldn't you rather just pressure test it first? I bought a pressure tester off eBay for about 40 quid.
    Also worth getting a Vagcom cable to help identify any problems.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    as above a good pressure testing session and vag com
