a couple of weeks ago my rear wiper motor packed up so today i decided to have a look and see if a fix was possible. i removed the complete unit from the car then i detached the gear cover only to find the internal steel gears badly corroded then i took the motor off to allow me to turn the gears by gripping the shaft that the wiper arm fits on with a pair of molegrips i drenched the gears in wd40 and worked them eventually it freed up i kept spraying wd40 and working the gears until they was running freely then i filled the gears with copperslip grease and again worked the gears to get it in everywhere then i reattached the internal part of the motor and temporarely fitted it back on the car i did this so i could manually turn the water jet hole so it lined up with the wiper arm when at rest i took it back off the car and fitted the motor cover and the gear cover then i fitted it back on the car plugged it in and tried it it worked perfectly i attached the water hose reassembled everything and now it works just fine it only took an hour with a few basic tools and i saved myself about 60 quid so if your rear wiper as stopped working give it a go you have got nothing to lose
