Sky InsuranceAH Fabrications
Results 1 to 14 of 14
    sam4191's Avatar
    If In doubt, Flat out!
    Feb 2009
    Highcliffe, Dorset
    399
    What is this called and where can i get one?
    Hello!
    this has been bugging be for a while now, but the triangular bits on the rear of the rear doors are all corroded up. I don't want to try to repair them myself, as it seems to have a delicate finish. Does anyone have any idea of where I could get a replacement from, other than Audi, how much do you reckon they cost and would it be easy to replace? I have looked but looks a little daunting.
    A pic of the bit I'm talking about is below;
    Cheers guys!
    Nov 2008
    Southampton
    58
    mine are on the way out too, but not too bad, would be usefull if anyone knows!
    Jul 2008
    Birmingham
    629
    They've got some glossy ones on a facelift car down the scrappy but it's rear electric windows and I couldn't work out how to get the window down and remove it.
    A4 1.8TQS
    Jul 2008
    Birmingham
    629
    A4 1.8TQS
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    Its a door frame off job to remove it IIRC. Not difficult, just time consuming for the sake of a silly trim
    mac1403's Avatar
    Sep 2005
    wales uk
    956
    They all corrode. I did mine myself just masked everything up and got the grinder on it. When the bubbling paint was removed the corrosion wasn't that bad. Just treated and primed with some etch primer then sprayed gloss black. Lasted with no signs of it returning for the 2 years I kept the car. Easier than dismantling the door frame.
    Facelift S3, Sprint Blue, Bucket seats, Sunroof, Sat Nav, Bose, Elect Mirrors, Light and Rain, Interior Light pack, Flat Tyre Warning, GSM Phone Prep, Led upgrade, Illuminated speaker grills.
    dieselfitter251's Avatar
    Blow ma own trumpet?
    Jun 2007
    High 'C's
    1,130
    Aye, easier fix than getting the whole door to bits, in fact, that's the easy bit, putting it back together and driving with out any wind noise is the pita. I think my drivers door has just about re-bedded in ...
    A nice hammertone paint would look lurvley .
    Ford Mondeo 2.0i Durtec Ghia X Estate
    Leather / Dog Hair.
    Dieselfitter 251
    A4 avant '97 1.9tdi q
    a.k.a. STINKY
    [B]250k!
    ..she's gooooonnnne!!!!
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    I was thinking about flatting and priming them, then getting some carbon-look vinyl to cover them... and cover the B pillars to match.
    Good idea?
    jcb
    Sep 2005
    uk
    4,077
    rear door outer sail trim. 23 each in primer from Audi.
    just pull them your self and paint. easy and cheap
    You do not need to take door frame off.
    pull door card.
    remove inner sail trim cover carefully (they break!) it is hooked on and has one central popper attachement.
    Outer Sail trim has a Torx or Hex bolt holding it in place (sorry can't remember)
    it is also held in place by the rubber seal outside.
    undo torx bolt, crack the two door frame bolts but do not remove, a few mm of thread allows you to open the door frame to door gap enough to pull the sail trim out.
    refit while you flat off with 250 grit, 500 grit, 1000 grit.
    two coats primer, flat off with 1500 grit and two coats of gloss black.
    total cost...one tin of paint as I already had the sandpaper.
    I actually did buy the audi ones, one came threaded for the bolt and one came with no thread tapped. cheap *******s wouldn't take it back and i had to retap it.
    fitted the new ones, painted up the old ones and sold them for 20 on eBay!
    don't like carbon look myself.
    Jun 2007
    High 'C's
    1,130
    ^^^The man knows his stuff! And made money back! Recycle Re-use Re-sell Reap the cash.... how green.. :O) nice one!
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    Geeman's Avatar
    Low Life
    Mar 2009
    Grimsby
    1,318
    I tried taking one out yesterday before reading the DIY guide... I undid the torque bolt, but because I didn't undo the door-frame bolts I couldn't get it quite out, so put it back together again. Will try again this evening now!
    NOTE: be careful with the inner cover... I snapped the locater pin off. Doh!
    jcb
    Sep 2005
    uk
    4,077
    Quote Originally Posted by Geeman View Post
    Quote Originally Posted by jcb View Post
    pull door card.
    I know!! I broke mine as well!!
    griswold's Avatar
    340
    Voteforpedro What scrappys is that then? as i'm in cardiff
    A4 1.8T Quattro sport
    A6 2.4 Avant SE
    sam4191's Avatar
    Feb 2009
    Highcliffe, Dorset
    399
    sweet, nice one guys, I think I'll go for the repair! seems waaaay too much trouble just for a little bit of corrosion! cheers!
