Sky InsuranceVolks Autos
Results 1 to 18 of 18
    Mar 2009
    Bethesda, North Wales
    40
    s4 not running boost....
    hi guys, i have been on the s4 forum for a while and cannot seem to get any closer to solving my problem, so now i am looking for a new angle on things
    these are things that i have changed or inspected...
    02 sensor bank 1 no codes coming back now
    boost controll valve 'n75' code still there
    maf sensor, never been a code but the are known to be hidden faults
    checked all boost pipes including tbb and f hose
    there is no restriction on revving it drives so smooth, and every now andagain she will kick in full boost will be ok for a gear change, then its gone back........
    any input welcome, thank you in advance
    osian griffith
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,909
    If its making no boost the N75 valve code is the one to be looking at.
    What exactly is the code?
    We were getting an intermittant open circuit code on the N75 on our 1.8T and it turned out that the wiring was broken. I replaced the last 12" of wiring with that from a loom from a breaker and the fault vanished and my boost returned.
    It could be the valve itself though, have you tried changing it?
    If the valve or wiring is broken it will run at actuator pressure, which is about 4psi.
    An intermittant wiring fault like ours would likely cause the symptoms you describe, ie sometimes it will boost perfectly and othertimes theres nothing.
    TD5 Land Rover Defender build
    Lee Goodall's Avatar
    ..got my head together!
    Oct 2007
    UK - Midlands
    2,223
    Yeah I'd def say either faulty N75 wiring (if the code is open circuit) or faulty N75.
    I had the same issue as Aragorn but the wire had snapped right near the N75 plug/connection so I just trimmed it down and rewired back into the plug.. job done!
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    You haven't mentioned if you've run a pressure test. I'd look there first.
    Have you checked/swapped any of the common failure points, ie: DV's, TBB, F-hose, etc?
    You should also run some Vagcom logs if you are able to.
    Which S4 forum have you been looking at?
    Mo power, mo problems
    Oct 2007
    UK - Midlands
    2,223
    If there is a fault showing with the N75 then that will be causing boost control issues.
    A boost system pressure test would obviously rule a boost leak out too though.
    Feb 2007
    Liverpool
    1,691
    Sorry, just re-read the original post and saw that your N75 code is still there.
    Get it sorted!
    Mar 2009
    40
    no i havent done a pressure check, i really want to do it just for peace of mind, can any one put me through the steps of doing it, and an easy way of making a tester rather paying 50 for one haha.....
    the n75is a new one genuine audi part,,, didnt get the codes cleared but the car has been driven roughly 500 miles, same as always.
    i will check the wiring on the weekend.
    cheers for the input guys, my car is running 4 psi by the way haha
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    4 PSI is Limp mode, you deffo need to get that N75 checked out
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    physically check intercooler pipes throttle body and F hose ie take it off and check the underside .
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    Feb 2007
    Liverpool
    1,691
    You didn't get the codes cleared??
    1) Get on Vagcom, go into Engine module, then 'measure blocks' then choose block 32 and post up the values.
    2) Clear the codes.
    3) Go for a decent drive.
    4) Check for fault codes again.
    5) Let us know how you get on.
    Mar 2009
    40
    the engine management should re evaluate all reading after 300 miles so it should have picked the new one up by now, i have checked all pipes, removed and checked all over,,,,, twice.... ill check the wiring on saturday ill let you know how i get on
    "Stick a V8 in it!"
    14,909
    The codes will remain, even if the fault has been gone for several thousand miles...
    The only way to know if they are current is to reset them, and then see which return.
    Oct 2007
    UK - Midlands
    2,223
    I do seem to recall reading that the ECU will only keep codes stored for 300 or so miles.. So in theory if you've corrected the issue the codes will be erased.
    Feb 2007
    Liverpool
    1,691
    Quote Originally Posted by s4 osh View Post
    I'd not heard that.
    300 miles is a lot of laps round Anglesey! lol
    I picked up my S4 from Anglesey. Spent it's first 8 years there.
    Mar 2009
    40
    wel hopefully i will have vag com tomorrow to see what the hell is going on lol, was it from holyhead you got the s4 from, negaro blue???? if so i believe thats a good buy
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    nogaro
    Feb 2007
    Liverpool
    1,691
    No, mine's a Minger. Bought it from a guy called John in LLanfechell just over 2 years ago.
    Mar 2009
    40
    coolio i know someone had a nogaro in holyhead, but ihad no idea bout the one in llanfechell, my missus's step dad lives there... small world
