AH FabricationsChris Nott
Results 1 to 22 of 22
    Mar 2009
    6
    Airbaglight - yellow contact?
    Hey!
    I've had the airbag light since I bought my A4, 1.6L, 1995 model for over 1 year ago.
    I recently ran Vagcom on it, with the following fault code:
    Code:
    Address 15: Airbags
       Controller: 8A0 959 655 C
       Component: Airbag V AUDI      D00
       Coding: 01022
       Shop #: WSC 33977
    1 Fault Found:
    00588 - Airbag Igniter: Driver Side (N95)
                32-10 - Resistance too High - Intermittent
    I've been told that there should be a yellow contact underneath the driver's seat that most likely is the problem.
    Like this: http://farm4.static.flickr.com/3229/3132287793_d327a42d40.jpg?v=0/3229/3132287793_d327a42d40.jpg?v=0
    But I can't seem to find this contact.. Do I have to remove the seat? Am I blind? Or is it simply not there? (Don't have side airbags)
    joost's Avatar
    Nov 2005
    Lancs
    1,166
    This link might give you some idea - the contact underneath the seat seems to be the culprit in this case too.
    Justin
    2001 VW Golf 2.3 V5 (170) Highline, Indigo Blue - standard, for now...
    A4 (B5) SE with a few slight amendments here and there (sold)
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,354
    Isnt that the Airbag in the steering wheel ??
    I wouldnt expect a 95 to have seat airbags tbh
    joost's Avatar
    Nov 2005
    Lancs
    1,166
    Fair point.
    I know there was a recall on the A4 for the earth on the wheel airbag as mine had to go in for it ('95 1.8). Strangely enough that has a yellow connector too...
    Justin
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    Ye that doesnt say side airbag, so i presume its the one in the wheel.
    Your '95 doesnt have side airbags either i dont think, our '96 certainly doesnt have them.
    Its most likely going to be either the earth mentioned above (my dads old '95 1.8T had the same fault iirc) or the contact ring that sits between the steering wheel and the column.
    TD5 Land Rover Defender build
    Mar 2009
    6
    So it is only the cars with side airbags that has this contact underneath the seat?
    26,720
    Quote Originally Posted by stian89 View Post
    Hey!
    Code:
    Address 15: Airbags
       Coding: 01022
       Shop #: WSC 33977
    1 Fault Found:
    Cars with side airbags usually have airbag written on a label on the side they were fixed to, my current has, my 8L S3 had & I'm sure my S4 B6 had it aswell, I'd hazard a guess if you dont have the airbag label its most likely they dont have airbags, got any image of under the seat.
    "Stick a V8 in it!"
    14,900
    Correct, the side airbags are in the side of the seats, hence the connector under the seat.
    In your case, it will most likely either be the earth mentioned above, or the contact ring in the wheel itself.
    the matrix is comin
    Jan 2009
    ramsgate
    147
    have you tried resetting the vagcom then turn the steering from one lock to the other and if the light comes on then its the clock spring in the wheel itself
    built in germany caressed and loved in england.
    Mar 2009
    6
    Quote Originally Posted by stub View Post
    I'll try this tomorrow, thanks.
    Not fun to run Vagcom, I have 8 engine errors..
    26,720
    8 engine errors, think you need to clear them sooner than the airbags mate cause the airbags will be irrelevant if the engine goes & I maybe wrong but think the others mean the Slip Ring behind the steering wheel, these dont go wrong very often tbh, unless you've disconnected the lower steering linkage in footwell & turned the wheel 1 turn either way so the slip ring is not centred which then pulls the slip ring connections out on full lock potentially, have you had any of this of or messed with lower linkages etc?
    "Stick a V8 in it!"
    14,900
    NHN: Its more likely to be the slipring than the airbag itself though...
    Stian: What are the engine fault codes? Its probably worth making a note of them, then clearing them and seeing what comes back...
    26,720
    Anythings possible I guess, the lube could of dried up over time inside the slip ring & not allowed such smooth movements of the ribbon, thus pulled on the tracks inside the ribbon or the ribbon connections, but they hardly go wrong, but as I said anythings possible & hope its this as its a cheap fix huh
    Mar 2009
    6
    The airbag light has been there since I bought the car in November 2007, so I don't know what has happened..
    Engine error codes:
    18010 - Power Supply Terminal 30: Voltage too Low
    P1602 - 35-10 - - - Intermittent
    * This is because my battery dies when I don't use the car for over a week.. Been searching for the fault, and I hope it's fixed now.
    16500 - Engine Coolant Temp. Sensor (G62): Implausible Signal
    P0116 - 35-10 - - - Intermittent
    * Need to locate the sensor and figure out where to order it.
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-10 - - - Intermittent
    * Haven't had the problem with the car "dying" after starting it in a long while. But when I reset this fault, the problem has returned. Solution: Solder some wires in the "starter" where you put the keys (not good with english expressions..)
    17736 - Knock-Control: Cylinder 4: Regulation Limit Exceeded
    P1328 - 35-10 - - - Intermittent
    * No idea what this is.
    01249 - Fuel Injector for Cylinder 1 (N30)
    26-10 - Output Open - Intermittent
    16705 - Engine Speed Sensor (G28): Implausible Signal
    P0321 - 35-10 - - - Intermittent
    * When the car "stands still", the motor RPM sometimes goes crazy.. Need to locate and replace this sensor.
    00561 - Mixture Adaptation
    14-00 - Adaptation Limit (Add) Exceeded
    16514 - Oxygen (Lambda) Sensor B1 S1: Malfunction in Circuit
    P0130 - 35-10 - - -
    Thanks for the quick replies!
    26,720
    I'd certainly fix those errors before doing airbags, lol
    "Stick a V8 in it!"
    14,900
    This is located at the back of the cylinder head, in the black metal pipe, new sensor is about 20 quid and is easy to change, however the intermittant nature MAY point to the wiring being at fault.
    I doubt you clearing the fault codes will have braught this back. Probably a faulty reader coil.
    This means your engine is suffering from pre-ignition on that one cylinder. This is bad, but it might just be due to the fuelling being off, due to some of the other faults
    This is the fuel injector on cylinder 1.
    This is the crank sensor, its mounted at the rear of the motor, ontop of the gearbox bellhousing, and reads from flywheel teeth.
    This says your fuelling is waay off the scale. You need to fix the temperature sensor and lambda and see if this comes back.
    P0130 - 35-10 - - -
    This is the sensor in your exhaust, just before the CAT, which detects and controlls the fuelling. This needs replaced.
    With all the fuelling errors you have i'd be surprised if its returning 20mpg!
    You need to get all of these things sorted asap, as they can damage the engine if not corrected. Replace the Coolant temperature Sensor and lambda and clear the codes and see what returns.
    Mar 2009
    6
    Thanks for the reply.
    Will order new sensors ASAP.
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    boy you have your work cut out there, good luck
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    Mar 2009
    6
    So I should focus on these two, and don't replace the Engine Speed Sensor (G28)?
    Apr 2009
    76
    i also have had an airbag light come on the dash as of late. I had also played with the steering column and seat heights when cleaning the car recently so might have disturbed the connections somehow.
    not wanting to spend a fortune with someone who owns a VAG computer, if i disconnect the battery for a while and try and fix the fault, will it clear the airbag light when i reconnect it assuming i have rectified the problem?
    "Stick a V8 in it!"
    14,900
    No.
    The fault needs cleared with vagcom.
    Where are you located, someone on the forum might be nearby and be able to use their vagcom on it for free/much cheapness.
    Apr 2009
    76
    Am in Rotherham mate S Yorks
