EM TuningJMB Retrofits
Results 1 to 14 of 14
    Mar 2009
    45
    Just got my S4, thanks for all your help!
    Hi guys, thanks to those that helped me find one of these over the last couple of weeks. Just got an Imola yellow S4, completely unmarked inside and out, front suspension arms, discs, pads, 2nd timing belt all changed recently. Got it for 4900. Drove it around 200 miles so far and it drives very nicely indeed.
    Only thing Is with it, the engine is makes a wierd sort of like... fan chechchecheche (<<<no idea :O) type sound whenever accelerating. It's not that loud and also when the engine is idle it goes away. I'm a bit worried about this but am getting it checked out at the weekend.
    Oct 2007
    2,597
    Glad you got your dream car at last!
    Be sure to regale us with some nice pictures.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,523
    Get the cams checked,it wont cost any more than a few cam cover gaskets to check if you are handy with a spanner and could potentialy save you a fortune
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    Have you tried contacting the previous owner to see if they can shed any light on it?
    Does it only happen under load, at a certain rev range, dependant on amount of throttle, etc??
    Could be something as simple as a loose heatshield.
    Mo power, mo problems
    Mar 2009
    45
    Previous owner does not recall this sound. It seems to be constantly, no matter what rev range, throttle etc. When the engine is idle however, it goes away.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,389
    what if you raise the revs with the car stationary?
    can you get someone to hold the throttle open a little while you pinpoint the noise from under the bonnet?
    TD5 Land Rover Defender build
    Mar 2009
    45
    Yeah I tried that with a matey, but from the outside the engine drowns out this noise. You can only hear it from inside the car! And I'm fairly certain it's not anything inside the car making the noise. Real pain, I'm going to try and take it to MRC tomorrow and get it health checked. Fingers crossed it's nothing too serious..........
    "Stick a V8 in it!"
    15,389
    hmm ye ours has a noise that comes and goes but does the same, audiable whine in the car but under the bonnet its drowned out by the clattering the rest of the motor makes :P
    audinary's Avatar
    Aug 2008
    Frinton-On-Sea
    646
    Not a leaf stuck in the heater fan?
    My dad had a noise in his Mondeo ST which sounds like that, he was ****ting bricks before I found greenery in his vents.......
    Good luck and enjoy your car you lucky swine.
    '98 Santorin Blue 1.8t Sport
    stapo69's Avatar
    All hail the mighty quattro!
    Mar 2007
    966
    What does a helth ceck cost now? Wanna get one done before my Ring trip
    MRC-Powerflex-Hotchkis-Porsche-Compomtive-Vredestein-034-JHM-Apikol-EBC-FK-Labree-Vibrant-Recaro
    Mar 2009
    45
    MRC do it for 50 atm! I just spanked 300 on new DV's, MAF, temp sensor with the healthcheck and labour.
    EDIT: Have had 2 different oppinions on the other issue,a little unsure still as to what this could be. Probably expensive....
    stapo69's Avatar
    Mar 2007
    966
    ta, hopefully mine should be ok, had new dvs, boost pipes, maf, temp sensors, lambda probes, thermostat, downpipes, exhaust over the last year, just want her checking over before caning er 900+ miles! That's a good price, be stupid not to do it really!
    Glad yours is getting there, she'll be sweet before you know it! I've had a knocking noise at the rear for nearly 2 years now, stripped it numerous times, 2 garages have looked at it, replaced everything we could think of! Still not found it!!!!!! But nothing's fallen off or broken yet!
    Mar 2009
    45
    Yeah worth it all the way, Dougs seems a nice bloke! It's looking more and more like a replacement exhaust manifold. I assume engine out is the only way to do the manifold on these? will get rid of that push fit crap and get some welded ones put on if thats the case but I dunno If im ready to pay for an engine lift just yet..
    Fraser's Avatar
    Aug 2003
    the north
    586
    not a cheap fix for that unfortunately
