Sky InsuranceChris Nott
Results 1 to 10 of 10
    A4Chris's Avatar
    Mar 2008
    Fife
    1.8T drop in MPG and misfire
    Whilst I know this will be a case of running a diagnostics (which I don't have easy access to) I'm just wondering if anyone has any 'starters for 10'?
    My average MPG on my 1.8T (AEB) has dropped from 35 to 26, idle is rough and misfires when under power (especially in 3rd gear for some reason). Also, low down torque seems to have gone and top end punch dissappeared. Basically running rubbish!
    MAF was replaced with an OEM replacement 16 months ago so don't think it's that. Thinking it could be an ignition coil? Also, worth noting that passed MOT whilst running like this so presumably emissions (and therefore Lamda sensor?) okay??
    HELP??
    A4Chris
    B5 Audi A4 1.8T Sport (standard)
    Sandip's Avatar
    Nov 2006
    Greater Manchester
    2,379
    Could be the ignition amplifier module, its on the top of the airbox, has two plugs going on to it
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,520
    Either gnition module, in which case its usualy cyl 2 that goes first.
    I recently had much the same, my car would idle fine, and miss on high boost, turned out to be a coilpack for me. I am sad and actually carry spare coils and an ICM in the boot
    A4Chris's Avatar
    Mar 2008
    Fife
    Thanks guys - I'll look into this further at the weekend. Might go down the route of replacing all 4 coil packs to rule coil packs out if nothing else - or hopefully fix the problem (looks like the coil packs are the original ones so at 145,000 miles old can't do any harm to replace them!)
    Thanks for the quick responses.
    Chris
    A4Chris
    Apr 2004
    12,520
    I would certainly do all four if you can, but i would play swappsies and find the culprit so you can keep the 3 "good" ones for spares, you never know....
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    might want to check your spark plugs before changing any of the expensive parts...
    TD5 Land Rover Defender build
    Dec 2008
    48
    whats the best way to test if a coil pack is faulty, would this show in VAGCOM
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,389
    anyone know how much a ignition amplifier module is ?
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    Aug 2009
    Sounds very similar to the problem i had, the garages i went to see did a few things that never worked like the MAF. In the end i got myself 1 coil pack and swapped it around all 4 of the old 1s, it turned out to be the last one i tried!
    mwarrey's Avatar
    Dec 2003
    Swansea
    281
    Quote Originally Posted by richie_jones View Post
    As far as I know, swapping each in turn with a known good one is the only way. The fault doesnt register in the ecu even with a major misfire. There is a way of testing the ignition module with a simple test rig you can make yourself. It shows you how here :- http://forums.audiworld.com/showthread.php?p=1535031
