Sky InsuranceChris Nott
Results 1 to 11 of 11
Thread: E/W troubles
    Mar 2009
    53
    E/W troubles
    im having trouble with my electric winows on my 95 a4 b5. both the windows are completley frozen, i was told to listen for any noise when i try to roll them down but the only thing i get is a soft click when i press the drivers control for the passenger window but when i press the passengers switch i hear nothing... any ideas?
    Oct 2007
    2,597
    Could be a dead motor...
    Does the interior light dim when you operate the controls?
    Mar 2009
    53
    nope i do have a spare motor.. but if it is the one motor how come both dont work? and how will i find out which doesent work?
    Oct 2007
    2,597
    You'll need to check for power to the connectors within the door.
    If none, it could be a control unit issue. It's the large relay under the driver's side shelf (accessed by removing the panel below column).
    Mar 2009
    53
    actualy when i press the passanger window switch the light dims very slightly, but i also noticed i can feel the "click" if you get what i mean, but still no movement whatsoever with the drivers side, and the light doesent dim when i press that switch either
    Oct 2007
    2,597
    In that case, the driver's side motor or switch have gone open circuit.
    Passenger side is possibly seized.
    Mar 2009
    53
    im no expert but i dont mind a bit of DIY, so how would you recomend i go about fixing/diagnosing further?
    Oct 2007
    2,597
    For starters, I'd connect your spare motor to the passenger's side, and test it again.
    Driver's side will need a continuity test, it's possible to have a broken wire in the rubber grommet / boot between the door and A-post. I'd test for power in the kick-panel side to begin with.
    Mar 2009
    53
    right ok, weather looks like its about to turn for the worse so il have to leave that for another day but cheers for the advice (Y)
    Oct 2007
    2,597
    Bad weather?
    Very sunny here. Where abouts are you?
    Mar 2009
    53
    wolverhampton
