JMB RetrofitsAH Fabrications
Like Tree1Likes
  • 1 Post By imported_kev_turbo
Thread: dash problem
    johnyj's Avatar
    Jun 2004
    253
    dash problem
    in my a4 the electric dash in the middle of the clocks is ok when you first turn it on after a while it fades and splits up the digits.
    is this pricy???
    also i have seen an ad on e-bay about a code to unlock displays like speed and rpm does this sound right? [img]/ubbthreads/images/graemlins/laugh_roll.gif[/img]
    Mar 2004
    Cheshire
    922
    Re: dash problem
    is it the aircon one? dead easy. only works with climate control.
    press recirculate and vent dash then scroll to 17 or 27 and press recirculate and it will display speed in kph or revs.
    Dash display is a fault which is rather expensive to fix as you need a new speedo unit. unless it is under warranty i wouldn't bother
    johnyj's Avatar
    Jun 2004
    253
    Re: dash problem
    ill try it out, its a t reg so not under warranty.
    so ill leave it..
    thanks
    imported_kev_turbo
    Re: dash problem
    send me a mail kevinandhazel@ntlworld.com so I remember. It is about 7 pages A4 when printed though a lot of the codes make no sense at all (e.g. heater motor voltage etc.)
    Kev
    cuke2u likes this.
