Monster MotorsportBadger5
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,390
    S4 Xenons into pre-facelift
    I have a set of pre-facelift s4 Xenons and am planning on fitting them into my car which has standard pre-facelift lights.
    are these plug and play or do they need adapting? the wiring connector looks the same but looking at some web pages they show different set ups for factory fitted xenon light replacements and non xenon set ups so they will be plug and play.
    so will I need to mod the wiring so these fire up when fitted to a car that does not have xenons from factory? or should I just sell these on?
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    I'd say the only difference would be if your existing lights have integrated fog lights, which the S4 lights don't.
    Should be plug and play. Why don't you just connect up one of them prior to fitting to check that all the bulbs work in the same way? That should take no longer than a couple of minutes.
    Mo power, mo problems
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,381
    i think the stock loom for xenon cars has an extra plug for the ballast, but i may be wrong?
    As blue says, give it a try.
    TD5 Land Rover Defender build
    Oct 2007
    2,597
    S4 2-piece HID's are plug and play in pre-facelift B5's.
    Feb 2007
    Liverpool
    1,693
    Aragorn, there are still only two wires to connect to the ballast. I think you may be mistaking it for the extra wiring for the auto-levelling adjusters. They have a seperate plug from the main light connector on the S4 xenons (pre-facelift).
