Im after a pump,just the module part realy. the part no is 8E0 614 111A. has to be in perfect working condition. its for a 2000 a4 1.8t quattro sport,not sure what other audi's it can be found in.
When i scanned the car the only thing the ABS controller was saying was faulty was one wheel sensor...
I dont know how you've made the jump from a faulty sensor to a dead module, but i'd be changing the parts it thinks are broken before getting into the expensive stuff.
its the module.it done the usual thing when they go so i had a go at fixing it but broke one of the tiny wires that you can hardly see so thats what will be giving the code.i have a module i tried out an a6 and it never gave a code for a sensor but i think it was goosed in the same way mine was to begin with.
ill need to check the numbers but the pump was same number but with AH at the end instead of A.sometimes the abs light would go out with it but as soon as you touch te brakes the abs came on.when plugged in it would sometimes say my front right abs sensor was away then other times it couldnt communicate with it so im guessing its ****** too.
