Monster MotorsportChris Nott
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Brake disk question
    I have the S4 disks as i am doing a custom upgrade for the fronts. They are 30mm standard thickness on them it has 28mm min thickness written on them. Does that mean after 1mm has gone from each side there useless?
    Thing is i have had them skimmed to 28mm anyway to fit the calipers im using just a technical metal\engineering question really.
    Its not going to stop me using them as the standard ones i have now are warn at least 1.5mm and stop me with no problems and there rusted to fcuk.
    I just wondered why they had it written on them is it also becasue there cheap copies?
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,900
    thats the manufacturers spec for minimum thickness.
    Not really sure what dictates the minimum thickness though.
    TD5 Land Rover Defender build
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Thats what i was thinking ill use them until i want to replace them not because somone else tells me to
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/showthread.php?t=43296
    jcb
    Sep 2005
    uk
    4,070
    my RS4 discs have the same "guidelines" but so long as they are working and don;t have a huge lip I will expect to take them past the 1mm either side rule
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    Thanks for the advice I was thinking that 1mm was just a little bit less than i thought a disk could handle.
