- Joined
- Jan 30, 2008
- Messages
- 18,708
- Reaction score
- 909
- Points
- 113
- Location
- Glenrothes, Fife, Scotland
So we were out today in craigs S4 and on a few occasions when we stopped i could smell petrol.
At one point, we backed the car out of a space and there was the tell tale rainbow patterns on the road, so i had a look under to see what was going on.
On the right hand side of the tank, near the subframe mounting bolt, there is a silver cylinder which is tucked tight against the tank and has a banjo fitting on the bottom. I presume this is the fuel filter.
Fuel seems to be leaking from the banjo joint from what i can see. Any ideas if this is a common problem? will i just have to replace the banjo bolt and seals, and put a new filter on for good measure, or is it likely that the banjo itself is causing the leaking, ie a replacement fuel line being required...
