Volks AutosMonster Motorsport
Results 1 to 11 of 11
    stapo69's Avatar
    All hail the mighty quattro!
    Mar 2007
    966
    Retro fitting cruise control part question
    Anyone know what parts, with numbers, I'd need to fit cruise control on my 1998 Audi S4? Looking on ebay and the audi b5 kits are around Ł150-Ł200, however the b5 Passat kits are easily Ł100 cheaper, I know these share a lot of parts with ours, but what about the cruise control? All look very similar from the pictures, same stalk and loom, but I don't know if it's that simple.
    Any help appreciated as always!
    MRC-Powerflex-Hotchkis-Porsche-Compomtive-Vredestein-034-JHM-Apikol-EBC-FK-Labree-Vibrant-Recaro
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Do you have to have a Drive by wire car to fit cruise control?
    Oct 2007
    2,597
    ^^^ All S4's are DBW.
    Jul 2007
    338
    do you need a loom to retro fit it? i had always assumed it was just a cash of plugging it into what was there and then enableing it in vag com.
    the stalks are available from american ebay for around Ł50. if you order some, let me know, we might be able to save on postage as i need some for mine as mine dont work propperly (only the 'set' button works, and it wont resume.)
    1999 Audi A4 1.8TQS (Standard)
    2003 VW Golf GT TDi
    2002 Audi S8 4.2 SOLD
    2004 Alfa 156 2.4JTD 20V Veloce SOLD
    2000 Audi A4 2.8 Quattro tiptronic (Electric heated seats, winter pack, lowered on H&R Springs & 18" A8 sport wheels) SOLD
    1999 Audi A4 1.9TDI 110hp (with full Audi Sports kit) SOLD
    rasA4's Avatar
    Four Rings Mafia Specialist
    Apr 2003
    Deep
    3,096
    on my facelift im sure it was plug and program on vagcom.
    i think it may be a common problem whenever i used to use resume the cruise would stop working if i pressed set again, i try not to use resume now just set it again.
    Bee Five | A4 2.4 V6 30V Tip SE | OEM S4 Alloys | S4 Bumper | S4 Leathers | HIDs| Billy's & Bachs | I Aint new to this | Hit the THANKS Button if my post is any use |Thanks!
    stapo69's Avatar
    Mar 2007
    966
    A lot of vag motors only need the stalk and a couple of wires, then vagcom, like my mates golf 4, but the earlier ones, like my 98 S4 need a loom as well and thats what ends up costing, so doesn't look like i can get away with a passat set up for some reason, can't find a cheap way to do mine, around Ł200 is the best so far, so looks like my 900 mile round trip to germany will be done with an achey leg!
    SiGainey's Avatar
    Sep 2003
    North Wales
    475
    Quote Originally Posted by Siena View Post
    My bad, I read it as A4
    audinary's Avatar
    Aug 2008
    Frinton-On-Sea
    646
    Quote Originally Posted by stapo69 View Post
    ... so looks like my 900 mile round trip to germany will be done with an achey leg!
    A well set-up crook-lok will do the job, and allow you to drive hands free on the straights...
    Redneck autopilot.
    '98 Santorin Blue 1.8t Sport
    Jan 2004
    York
    1,641
    My 99 2.8Q needed the Loom and indicator switch. Worked out at Ł150, which was the loom from kufatec and the switch direct from York Audi. It's a mare to fit though as you have to run the loom from the ECU through the bulkhead and up the steering column. Not a hard job... just fiddly and if your not one for working with wiring... a bit daunting.
    8V S3 Sportback with options on order
    stapo69's Avatar
    Mar 2007
    966
    A shall be taking a brick then!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,904
    I've been buying the parts to retro fit it to our '96.
    As ours is DBC its a kinda standalone system that just yanks on the throttle spindle using vacuum thingy.
    I've managed to get the ecu, stalk, pump, actuator, some pipes and the clutch and brake shutoff valves from an A8 breakers on ebay (the parts are all the same). All i need to get now is the bracketry to attach the actuator to the throttle body, and some time buried in the wiring diagrams to pull it all together.
    I shall post an update when i get onto it.
    1997 S4 - PPC ÂŁ999 Challenge Track Car Build
    TD5 Land Rover Defender build
