Right, I'm beginnig to wonder if my thermostat is beginning to stick open?......
I'm sure that the temp gauge never used to budge off exactly 90 degrees C no matter how hard or gentle I drove but recently after long downhill coasting and periods of gentle throttle use the gauge is going down to beween 85 and 90.......its definitely moving!
Am pretty sure that the car is returning 1 or 2 mpg less than it used to as well!
The coolant temp sensor was replaced about 3 years ago so don't think that that is the cause of the changing coolant temp readings.......
Could these symptoms indicate a thermostat on its way out or am I barking up the wrong tree totally?
Thanks!
Thanks!
