JMB RetrofitsSky Insurance
Page 2 of 2 FirstFirst 12
Results 41 to 48 of 48
  1. #41
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    Ł15 philips dust buster thing did the job for me , i also removed the grommets from the drain channels and made even more slits in them . I also removed the pollen filter housing and re sealed it . Those drain hole grommets are rubish and clog up really easy , i dont really see the point of them to be honest
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
  3. #42
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    The sunroof has 4 drains one in each corner, maybe they are what is to blame.
    Chris
    The problem with common sense, is that its not that common.
    See my images @
    http://www.christianfrench.co.uk
    Own a dreaded BMW? http://www.bmw-sport.net
  4. #43
    Jul 2008
    Birmingham
    629
    So I bought a Black and Decker Dustbuster but I think I need to dry it out a bit more first.
    When I leave the fan heater on in the car, should I wind the windows down so that the damp air can escape?
    A4 1.8TQS
  5. #44
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,313
    hmm, i think if you wound the windows down all the warmth would just blow away?
    Perhaps try for a few hours with the windows up and see how it goes? or perhaps open one of the rear windows a crack?
    Be careful with the heater too, dont want you setting the car on fire! :P
    1997 S4 - PPC ÂŁ999 Challenge Track Car Build
    TD5 Land Rover Defender build
  6. #45
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    I'd be inclined to remove all the trim and dry it out of the car, might be difficult but if a job is worth doing its worth doing properly, also with all the trim out you can see where the water is coming in. Otherwise all this may be for nothing.
    Chris
    See my images @
  7. #46
    Jul 2008
    Birmingham
    629
    I got the carpet out today with a little help from Stanley (knife).
    Now I will let it dry out and I can concentrate on getting the inside of the car bone dry and, oh yeah, finding the damn leak. I will put the scuttle back together and then hose the car down and see if any water leaks in. If not, we can assume it was the scuttle tray.
    A4 1.8TQS
  8. #47
    Caesium's Avatar
    My BM is fixed!
    May 2004
    Hertfordshire
    4,858
    I'd check the sunroof drains as well mate
    Chris
    See my images @
  9. #48
    Jul 2008
    Birmingham
    629
    Quote Originally Posted by A4Quattro View Post
    I checked the front ones, which are by one of the hinges (lower one I think) for the front doors, and they seem fine.
    I believe the rear ones involve a trip into the boot and/or removing the rear bumper... can anybody clarify?
    A4 1.8TQS
