EM TuningBadger5
Results 1 to 18 of 18
    Feb 2009
    30
    S4 bumper fitting to a 1.8T avant
    Hi Guys,
    I have gone out and bought an S4 front bumper for my A4 1.8T avant (B5) 2000. I've had it sprayed (looks mint) and went to fit it today to find that the original bolts that screw into the center are too short. I went and bought some longer bolts but the bumper still seems to slip down out of place.
    If anyone can give me some advice it would be much appreciated.
    Tim
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    what is you car and what is the bumper as facelift and preface lift bumpers mounts are different, i think iirc you can swap them over but
    also you have to change the front mounts or modify them to hold the bumper.
    do a search on here loads of us have done this in the past and you should find the info you need and probaly photos to explain
    try this below maybe of some help
    http://www.audiworld.com/tech/ext46.shtml
    Feb 2009
    30
    Thanks, I have a 2000 facelift A4, think the bumper is also 2000. Looking at the S4 front impact absorbing rams where the bolts fit into look slightly different to mine, ill have search on the site..
    Tim
    Markey's Avatar
    Apr 2004
    KENT
    2,143
    I didn't change anything when i fitted the s4 front on my 1.8t apart from the side brackets.
    A4 Avant project now started ! see this thread ! http://www.audi-sport.net/vb/a4-s4-forum-b5-chassis/43296-bit-project-going.html
    If you think my post had a usefull purpose please say thanks
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,320
    i think the bumper shocks are differnt on pre/post facelift cars.
    You'll need a set of bumper shocks to match the bumper.
    TD5 Land Rover Defender build
    Feb 2009
    30
    Mine is the face lift 2000 (w) model the same as your MARKEY with the s4 front conversion. I've changed the side brackets to the s4 ones.
    You say yours just screwed straight on? Mine fitted on perfectly but the bolts wont tighten up to secure the bumper on solidly. They kept on slipping through. Did you have longer special bolts with the S4 bumper? when we tried tightening them it kept squashing the metal behind the bumper, and then it would slip back down?!
    "Stick a V8 in it!"
    15,320
    the bumper is slipping because the bumper shock is different
    You need 8d0807133C and 8d0807134c
    You have 8d0807133A and 8d0807134a as far as i can tell
    "Stick a V8 in it!"
    15,320
    actually, if you look up from underneath, can you see the bumpershock thru the hole before you fit the bolt?
    Feb 2009
    30
    Thanks guys looks like I'm going to have to go hunting for some new bumper shocks then.
    Feb 2009
    30
    didnt look up inside i was just feeling to screw it in..
    looking again at markeys build thread and it seems my a4 might be the face lift of his?! mine is also w reg but has the longer side repeaters, not square, and already has the steering wheel and air vents with red lighting that he is upgrading his to..
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    i would like an s4 bumper for mine.looks much better than the standard a4 one i think.
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,505
    Or you can make tubular spacers to fit onto the top of the bumper shocks you have. I was lucky i had the bumper shocks and side mounts when i fitted my S4 bumper to my non facelift car
    205man's Avatar
    May 2006
    worcestershire, uk
    1,016
    lol thats what i did say that u could modify them lol
    Feb 2009
    30
    Funny you should say that, we did try some tubular spacers but it seemed to bend the metal it was being attached to when tightened... spent about 4 hrs trying different methods none of which worked :-)
    Oct 2007
    2,597
    ^^^ Just buy the OEM facelift S4 mounting rams, and you'll be fine.
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,074
    How much do S4 bumpers fetch at the mo as I fancy one for mine eventually.
    Life begins at 140mph
    www.passionford.com
    Oct 2007
    2,597
    ^^^ New or used?
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,074
    Wouldn't mind a used one as long as it was in good condition. If a new one isn't too painfull though I would consider it. Eitehr way I'll need to allow for painting it
    www.passionford.com
