EM TuningAH Fabrications
Results 1 to 17 of 17
Thread: 5psi boost
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    5psi boost
    today on a trip to nottingham had normal boost but after a nice quick run i dropped to 5psi , tried turning off and on but nothing , hits 5psi dead not a spot over . Im gonna run vag on it in a min i suspect a egt . Where is the cheapest place now for egts?
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,324
    5psi is the actuators default pressure.
    Would imply the N75 valve, or the wiring to it, is dead.
    Or i guess perhaps the ecu having put the engine into limp mode, but i'd expect other signs of that such as lowered rev limit
    TD5 Land Rover Defender build
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    ok vaged it this is what i got.
    17963 - Charge Pressure: Maximum Limit Exceeded
    P1555 - 35-10 - - - Intermittent
    17579 - Shareware Version. To Decode all DTCs
    P1171 - 35-10 - Please Register/Activate - Intermittent
    17862 - Shareware Version. To Decode all DTCs
    P1454 - 35-10 - Please Register/Activate - Intermittent
    17524 - Oxygen (Lambda) Sensor Heating: B1 S1: Open Circuit
    P1116 - 35-00 - -
    16518 - Shareware Version. To Decode all DTCs
    P0134 - 35-00 - Please Register/Activate
    17867 - Shareware Version. To Decode all DTCs
    P1459 - 35-10 - Please Register/Activate - Intermittent
    17536 - Fuel Trim: Bank 1 (Mult): System too Lean
    P1128 - 35-00 - -
    17777 - Shareware Version. To Decode all DTCs
    P1369 - 35-10 - Please Register/Activate – Intermittent
    Then i cleared codes and boost is back but this comes back
    2 Faults Found:
    P1116 - 35-00 - -
    "Stick a V8 in it!"
    15,324
    16518 - O2 Sensor Circ.,Bank1-Sensor1 No Activity Detected
    Seems your bank1 main lambda is dead, or unplugged...
    "Stick a V8 in it!"
    15,324
    Odd big text there
    The ones that arent detailed the first time round are:
    17579
    Throttle Actuation Potentiometer Sign.2 Range/Performance
    17862
    Exhaust gas temperature sensor short 1 to ground
    17867
    Exhaust gas temperature sensor 2 range/performance
    17777
    Cyl. 5, ignition circuit short to ground
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    would that all be related to the lamba ?
    "Stick a V8 in it!"
    15,324
    fuel trim might be, EGT could if the fuel mix was weak, but that would affect both banks...
    Throttle is completely seperate, as is charge pressure limit exceeded.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    do you think that this would have anything to do with a rumble between from 80mph in 6th if you put your foot down cause that was gonna be my next post?
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    on the rollers!
    "Stick a V8 in it!"
    15,324
    How do you mean a rumble?
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    Feels like could be drive shaft or prop, just feel a vibration but stops if you let off , i have noticed for a long time i get similar feel when harsh acceleration when turning to the right out of a junction for instance.... maybe i should start another post regarding that instead
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    That wouldn't affect your engine perfomance.
    Your turbos were second hand weren't they?
    Mo power, mo problems
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    nah , turbos was new and sealed but , performance is back now after clearing the dtcs it just seems to of got a vibration probably not related but will have to replace lamba first i suppose
    "Stick a V8 in it!"
    15,324
    keep a very close eye on the DTC's
    Scan it every day, and keep an eye on them coming back.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    will do,ill take it for a health check with grizz when i can get a day off and do the lamba at the same time as i get the exhaust fitted.
    Wheres best to buy a lamba ?
    Feb 2007
    Liverpool
    1,693
    Grizz is stripping a burnt out RS4 at the moment, so he might be able to use one of those. Failing that, GSF might have some new. Not cheap though.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    thought they was like 30 or something . Anyone got a part number or replaced one? how many are there? Ive done the egts on the drivers side(easy side) is it a similar proccess , cant seem to find any guides
