Sky InsuranceChris Nott
Results 1 to 21 of 21
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    abs module/pump part numbers
    my car has an abs pump 8E0 614 111 A in it but it has the usual problem with them.i got a pump from an a6 8E0 614 111 AH. what does the H on the end mean? both look identical and i just want to fit the module part and it doea fit but i think it has the same fault as my current module so if i get the module from the a6 fixed will it work fine in my a4?
    dieselfitter251's Avatar
    Blow ma own trumpet?
    Jun 2007
    High 'C's
    1,130
    Hi Ian,
    I've been looking into this myself and asked the same question but had no reply or maybe nobody knows.... The letters after the 8E0 are obviously revision codes, (well I think so anyway). I'd guess that later revision codes should work with older cars but not the other way around. The bit I'm not sure about is that some part numbers start 8D0 and some start 8E0 (like ours...). Myabe something to do with them being avants? Believe me, I'm quite confused about this. No way to get a definate answer, apart from going to Audi Service and we know how cagey they are...
    Ford Mondeo 2.0i Durtec Ghia X Estate
    Leather / Dog Hair.
    Dieselfitter 251
    A4 avant '97 1.9tdi q
    a.k.a. STINKY
    [B]250k!
    ..she's gooooonnnne!!!!
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,379
    8D is the B5 platform
    8E is the B6 platform
    Why your B5 has b6 parts fitted, i dont know, but it seems according to the parts catalog they are the correct parts for the car...
    TD5 Land Rover Defender build
    Jimbo.King's Avatar
    Oct 2006
    Leeds
    183
    I had this problem a few months ago but managed to get an A version the same as what was fitted to my car, from what i found with searching around the numbers on the end refer to the set up of the car, e.g fited with traction control, quattro, fitted with electronic diff lock etc so they are quite precise to what part number you get, i think the AH was fitted to the passat which wont be quattro (unless 4motion).
    I got mine from ebay for about 80 all in so keep your eye on there unless you fit the AH one and send yours off for repair.
    The part number 8E0 614 111 A was fitted to the A4/S4, A6/S6, A8/S8 (Quattro's only) so dont just search for one off an A4.
    Hope this helps, J
    2007 A4 3.0tdi Quattro S-line, Lava Grey Pearl, 229+bhp, 6 speed manual, Cruise control, Auto wipers/lights, Parking sensors all round, RNS-E Sat Nav, Heated Volterra leather, Adaptive Bi-Xenon plus headlights, Bluetooth phone prep/voice control, DRL, i-Pod dock, Coming home lights, A4 B5 front spring seat mod, LED DRL/side light/numberplate lights, Window tints, Cupra R front splitter, Black front grill, 3.5" custom tail pipes, 8.5x19 Calibre Excalibre wheels running 225/40/19, ET30-R ET35-F.
    Jun 2007
    High 'C's
    1,130
    I'd kinda got to this conclusion but thanks for confirming it. I've now got an 8E0614111 AE to punt! Argh!!!!
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    Jun 2007
    High 'C's
    1,130
    Quote Originally Posted by ian52 View Post
    Hey man,
    I think the bosch part numbe is what we're looking for: 0273004284
    This ecu has all the whistles & bells... quattro, EDL etc....There's one for sale on EbayMotors USA - around 172 + shipping! urgh...
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    May 2008
    perth
    1,197
    not sure if its because its a facelift but its a b5 and as far as im aware its never had a new abs module in its life.
    Jimbo.King's Avatar
    Oct 2006
    Leeds
    183
    Boschnumber 0273004284 / 0 273 004 284
    Part number 1 8E0614111A / 8E0 614 111 A
    Part number 2 8E0614111E / 8E0 614 111 E
    Software level D10
    Manufacturer Bosch / Made in Germany
    Suitable for vehicles:
    Audi A4/S4 Quattro from 1995 to 2001 all with ABS and EDS
    Audi A6/S6 Quattro from 1998 to 2001 all with ABS and EDS
    Audi A8/S8 Quattro from 1994 to 2003 all with ABS and EDS
    Passat B5 4Motion from 1998 to 2005 all with ABS and EDS
    Part number 8E0614111E is the latest part number for 8E0614111A, so either part number will work.
    Jun 2007
    High 'C's
    1,130
    Nice one Jimbo... +1 item to keep an eye out for.
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    May 2008
    perth
    1,197
    any idea what the differance is between the A and AH?
    "Stick a V8 in it!"
    15,379
    AH is a fwd part i think
    Bosch Cross reference 0265220525
    I would look at swapping out that sensor before changing the module though mate, as far as vagcom was concerned, the module was perfectly happy, it was just saying front left sensor is "open or short to B+"
    Jun 2007
    High 'C's
    1,130
    ^^^2nded.
    I just got my replacement ABS unit (which is wrong - but now got one watcher on ebay - woo) and after redeploying vagcom it's now showing both rear sensors are at fault.. still got the 65535 code but the sensors even look toast. Will be doing that before replacing the ECU
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    Audi A4 2,8 V6 Q
    Feb 2009
    Oslo, Norway
    Same problem
    Hi. Got the same probl. with my ABS Module (8E0 614 11 A/0 265 220 408). What I've learned so far is that both mine and 8E0 614 111E will fit, but also repair-kit 8E0-998-375 will do.
    These two modules were found in Audi A4/A6/A8's from 94-00 and VW Passat's from 97-00 as far as I've been told, but almost impossible to find... My local Audi garage here in Norway want about 1000 to replace the part with a new one...
    Jun 2007
    High 'C's
    1,130
    Ouch, see if there's a BBA-reman or similar near you, they do a fix in the UK for 100, about 95% of the time t's just what's needed.
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    951
    951's Avatar
    Feb 2007
    North east
    493
    I have a spare one the number is 8E0 614 111 but it doesnt say A or B after it.Will this be compatable ??
    A4 Avant 1.8T Sport (183 bhp).
    "Stick a V8 in it!"
    15,379
    Dont think so. The letters signify different versions of the pump. The quattro cars ABS unit is a bit more complex than the FWD versions, and the two arent interchangable.
    Aug 2007
    87
    Quote Originally Posted by Jimbo.King View Post
    Software level D10
    so if you have a,b,c,d or e at the end of the part number it will work? or will it only work if the part number is the same or later?
    "Stick a V8 in it!"
    15,379
    only A and E are the same. Any other letter is not the same part
    Its a part number, not a revision number. It has to match.
    Jun 2007
    High 'C's
    1,130
    A 100% working ABS system is becoming my holy grail.... Just saving up for my new rear sensors now.
    Leather / Dog Hair.
    Dieselfitter 251
    a.k.a. STINKY
    [B]250k!
    May 2008
    perth
    1,197
    so what about A then AH? the AH is from an a6 and the A from my a4 quattro.
    "Stick a V8 in it!"
    15,379
    i cant find AH in vagcat, but google seems to suggest its a FWD pump.
