JMB RetrofitsAH Fabrications
Results 1 to 10 of 10
Thread: Code my key
    Izzy1's Avatar
    Vorsprung Durch Technik
    Sep 2008
    Birmingham, UK
    348
    Code my key
    How do I code my key via vagcom?
    Izzy
    Bora TDI sport
    Audi A4 TDI
    diesel-a4's Avatar
    Stoned As Fuk
    162
    what you mean code your key as theres 2 different codings that need done, one for the locking and one for the immbo
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    i took the battery out of my remote and now my central locking doesn't work. but my key does start the car.
    by the way i only have 1 key.
    Izzy
    Bora TDI sport
    Audi A4 TDI
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    can anyone help me out on this?
    or point me in the right direction?
    Izzy
    Bora TDI sport
    Audi A4 TDI
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,365
    TD5 Land Rover Defender build
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    cheers bud, will give this a try after work.
    p.s i managed to get that stuff sorted that you sent me.
    thanks
    Izzy
    Bora TDI sport
    Audi A4 TDI
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    just tried using the user guide from Ross-tech but no luck.
    went into (35) cent lock (10) adaptation and in the value was zero. so in new value i entered 1 - test - save but this did not code the key.
    am i doing something wrong here?
    please advise thanks
    Izzy
    Bora TDI sport
    Audi A4 TDI
    "Stick a V8 in it!"
    15,365
    once you open adaption you need to enter channel 01 and press read.
    It should then show you the number of remotes currently programmed
    You then nudge the new value up to 1 or however many keys you have, press test and ensure the test value says 1, then press save.
    Then within 15 seconds you need to press the unlock button on the remote.
    It also says that on some cars you'll need to clear the existing programming, by storing the value 0 first.
    Izzy1's Avatar
    Sep 2008
    Birmingham, UK
    348
    when testing the key do i need to take the key out of the ignition and then press the unlock buttom.
    i've put in 1 but then the test button becomes greyed out. will try again tomorrow by removing all codes and re-coding.
    Izzy
    Bora TDI sport
    Audi A4 TDI
    "Stick a V8 in it!"
    15,365
    I find on mine that i need to press the up/down buttons to change the values rather they typing them in.
    Also you need to keep the key in the ignition. If you take it out, you'll cut power to the ECU. Just press the button without touching the key.
