Sky InsuranceEM Tuning
Results 1 to 14 of 14
    nemo2182's Avatar
    Lord wont u buy me a V10 R8!
    Oct 2005
    uk
    110
    Unhappy Somebody Shoot me!! Gearbox knackered again!!!
    Ive not long had my S4 back from having my gearbox repaired, and today I missed 2nd gear horribly from a fast start. Thing is now I cant move through the gearbox properly, 2nd being near on impossible to select. I know it is probably shagged again, but anyone got any ideas????
    Nathan
    2000 B5 S4 - MRC Remap - RS2 Sparks - Pipercross Element (dried) + Modified Airbox - Forge Divs - Samco Hose's - KW's dropped 50mm - 18" RONAL R41 in gun metal grey - Black Diamond Combi Disc's + Predator Pads - Brushed Alloy Mirrors - Short Shifter - Full Recaro - Carbon Trim - Bose. More to come, watch this space.......
    Oct 2007
    2,597
    It's possible the selector's out of alignment, and may just need adjustment.
    I'd check the connection underneath the car, and make sure the bolt is tightened.
    nemo2182's Avatar
    Oct 2005
    uk
    110
    Thanks mate, I have to say I never missed it like that before!!it was like slow motion and the gear seemed to grind for an eternity!! 2nd gear was replaced when the gearbox was fixed, so surely its designed to take a bit of abuse. Is it expensive if its the selector???
    Nathan
    Oct 2007
    2,597
    If it's the selector that needs adjustment, it shouldn't take more than half an hour on a ramp, 15 - 20 at the most.
    nemo2182's Avatar
    Oct 2005
    uk
    110
    Im assuming you have seen this problem before then?????I have to admit one of the things im not keen on is the gearbox. big, heavy, clunky affair........
    Oct 2007
    2,597
    Yep - seen ill-adjusted linkages shift, or loose locking bolt allow movement.
    nemo2182's Avatar
    Oct 2005
    uk
    110
    I mean it literally feels like the gear has ripped out and got jammed in there, its so hard to select 1st or 2nd. 3rd, 4th, 5th and 6th seem ok though!!!
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    my second gear has always been my worst , ive just got to live with it but i remember test driving another one before this and it was the same . is it a common problem.
    this other b5 a4 seems a lot smoother
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    nemo2182's Avatar
    Oct 2005
    uk
    110
    Andy,
    Had a 1.8t b4 and I loved the gearbox!!The S4 is just not as refined as it should b, but then I know they had issue's with the torque. Ive been in a M3 of the same era, and that is alot better. Not sure what the v8's are like. Im just s***ing em because my gearbox cost me 1000 a few months ago!!!
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    I just noticed you have a short shifter, check that all the alignment is ok with that 2
    nemo2182's Avatar
    Oct 2005
    uk
    110
    I got one, but still havent put it on ;o) I really havent had a chance to do it. I think ill get it on when my mate has to check what damage ive done!!!
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,851
    Second Gear is a known week spot on the S4 box and I know the US do a upgrade kit to over come this.
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    sounds interesting
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,693
    JHM Motorsports do it. Uprated first and second synchros and an uprated shift collar.
    Mo power, mo problems
