Monster MotorsportEM Tuning
Results 1 to 9 of 9
    graham A4's Avatar
    A4
    Jan 2009
    what is that rattling noise
    hello, just wondering does any know why my 98 a4 makes a rattling noise from the fromt as i drive along over bumps, gear change is quite noisy too although i cant hear anything unless i have the window open so its not that bad, i was thinking it may be loose calipers or else its linked to the power train. this problem does not seem to effect performance in any way, any veiws would be greatly appreciated thanks in advance
    Oranoco's Avatar
    Jul 2007
    HertFORDshire
    3,082
    quite possible the brake discs are lipped and the pads have worn down so the pad back is rattling against the disc. Whip the wheel off and have a look.
    Life begins at 140mph
    www.passionford.com
    graham A4's Avatar
    A4
    Jan 2009
    I HAVE NEW DISCS AND PADS ON IT , VERY WELL MAINTAINED
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    15,370
    knocking over bumps is usually the front suspension arms
    Craigs S4 makes an odd rattling though, that i've never managed to place, and hes had the arms replaced already.
    TD5 Land Rover Defender build
    the matrix is comin
    Jan 2009
    ramsgate
    147
    i had that a few months ago. it turned out to be the top suspenion arm ball joint but it can also be the bush on the lower rear arm. hope that helps mate
    Feb 2008
    281
    i had that problem and it was two things it was the top arm joints, i got them done and that fixed the rattle through the steering wheel, the other rattle was one of the down pipes from the manifold, which is probably your problem if you cant fill it through the steering wheel. you here it most on coble stoned roads
    dieselfitter251's Avatar
    Blow ma own trumpet?
    Jun 2007
    High 'C's
    1,130
    Um, maybe the pad retainer springs? Best to replace with new ones when changing pads and discs as the exisiting ones can get bent on removal if they get a bit stuck on there. Gear change... not sure.
    Ford Mondeo 2.0i Durtec Ghia X Estate
    Leather / Dog Hair.
    Dieselfitter 251
    A4 avant '97 1.9tdi q
    a.k.a. STINKY
    [B]250k!
    ..she's gooooonnnne!!!!
    billybravo's Avatar
    MODERATOR
    Feb 2005
    stockport england
    1,044
    could also be engine mounts get under the car and check for play in all your arms mounts and bushes
    TopGear Stockport / Longlife Exhausts /
    www.TopGearStockport.co.uk
    Feb 2009
    Wiltshire
    97
    graham A4> Did you manage to fix this problem with your car? I've got the same problem with the avant I recently bought and was wondering what you did in the end to fix it?
    SOLD :: Ming Blue 99' 2.8 Quattro Avant :: Mats, boot liner and spare wheel for sale.
    Now Looking for a decent A4 Avant diesel for less than 1600
