AH FabricationsVolks Autos
    2000 a4 1.8tqs-yellow
    May 2008
    perth
    1,197
    bloody abs modules!
    my module went tits up as they seem to on facelift b5's so i got a module from an a6 from a breakers.put it on and it threw a code for front right abs sensor so changed it and now cant communicate with module so its dud as well and the sensor was probably ok in the first place.i had a go at fixing the original module and got rid of the flashing warning but the abs light was still on.im now thinking that it was maybe fixed and just needed the code cleared.im going to put the original one back on and clear any codes and see what happens.pain in the arse.anybody know if you can check the module while it is off the car?
    dieselfitter251's Avatar
    Blow ma own trumpet?
    Jun 2007
    High 'C's
    1,130
    I think you need some sort of test-bed / bench... so no. I'm replaceing mine as I've got a 65535 error code, not sure if a replacement will do the job so I may have a spare to pass on.
    Ford Mondeo 2.0i Durtec Ghia X Estate
    Leather / Dog Hair.
    Dieselfitter 251
    A4 avant '97 1.9tdi q
    a.k.a. STINKY
    [B]250k!
    ..she's gooooonnnne!!!!
    andybnwc's Avatar
    Jun 2007
    lancashire
    744
    i could do with one to see if it helps comunication with mine too this is my second already maybe we could have a post around ie try it on and if it works pay for it otherwise send on to the next member etc. just a thought. Same goes for vag com maybe someone could do a mail order rental for a fee?
    99 Nogaro S4 now black bonnet and roof,blackdiamond discs and pads,Hybrid K04 with uprated actuators ,Rs4 clutch custom lightweight flywheel, esp lightweight pulley set ,Rs4 intake pipes ,rs4 mounts ,full samco hose set,F-hose delete ,BMC carbon induction, full stainless exhaust with de cat pipes, custom chip,18"ultra lights,LED rear clusters,6000k xenons ,LED sides,KW coilovers,powerflex bushes ,Boost guage in pillar pod,isotta steering wheel and gearknob,B&M short shifter
    May 2008
    perth
    1,197
    today the light went out for a bit but as soon as i touched the brakes the abs kicked in so i had hardly any brakes.the light came on again and no abs but at least i could stop.
