Make sure you do what Andymac says, then the thing is held in with a sliding clip, slide it out and pull, watch out for the rubber ring. Assuming your new sensor comes with a new seal, have it to one side assembled and just slip it into the housing as a straight swap, you will lose very little coolant . make sure its pushed down properly or theclip will not go back in.
