Badger5Chris Nott
    May 2004
    5 Volt and Ground wire on 96 MAF?
    I was wondering if anyone with a technical manual knows whcih wire on the 96 MAF sensor is the ground wire and which one is the 5 volt wire. There are three wires comming out of the sensor, one should be a 12 volt, one a 5 volt, and one a ground wire. Thank you.
    1,361
    Re: 5 Volt and Ground wire on 96 MAF?
    This is the only info given in the service manual for the 1.8T, so not sure whether it applies to the MAF you are testing.
