Chris NottJMB Retrofits
    Jul 2008
    Birmingham
    629
    Low-pitched whistling noise on throttle
    I get a low-pitched, but not very loud, whistling noise when I rev at idle or slow speeds. Not sure if it's audible on the go because of the road/engine noise. I would guess so.
    So, which belt is this? I believe the timing belt was done recently.
    [EDIT] I meant high-pitched.
    A4 1.8TQS
    Dec 2008
    48
    http://www.audiworld.com/tech/eng6.shtml
    I have the same problem , but unsure how to fix
