AH FabricationsVolks Autos
    Jun 2004
    RWC, CA
    Weird noise in front end
    My 99 A4 Avant has had a strange noise coming from the front end for a while now and is getting worse only recently. This all started when I replaced the tires the first time. I had Americas/Discount Tire replace the stock tire and it seemed like they never got the balance right for the wheels. After 7 visits and rebalancing, the noise was less noticable, but still there. This was still true until recently. I had the 90k service done, they recommended new tires and alignment. Had this done and noise still exists. It is a wub..wub..wub sound the increases in frequency with vehicle speed and is more noticable when you are turning. My thoughts are either the wheel bearings or a CV joint is going bad. How hard is it to replace these?
    Anyone have any thoughts?
    Mar 2004
    Cheshire
    922
    Re: Weird noise in front end
    I would say it is the wheel bearings! Don't know as to how hard it is to replace. Would have thought you would have to take it to a garage to do.
    Mar 2004
    USA
    275
    Bearings.
    Jun 2004
    RWC, CA
    Hi Guys,
    Thanks for the info. I thought it was more likely to be the wheel bearing(s). It didn't have the symptoms of a CV joint. No grinding or steering pull.
    Since I don't have a bearing press or a press of any sort, I guess I'll have a garage do it. Any idea of what I should expect to pay?
    May 2004
    Ca, USA
    51
    A LOT
