Chris NottSky Insurance
Results 1 to 7 of 7
    Apr 2004
    Swansea, South Wales
    528
    VAG-COM Error codes
    A long time ago, I bought a cheap interface off ebay. Just got around to plugging it in to get the error codes. I now wish I hadn't!
    As you can see, I downloaded the shareware version, so not sure if I can reset any of the errors, but I would appreciate it if anyone could tell me what it all means!!!
    VAG-COM Version: Release 409.1-US
    Chassis Type: 8D - Audi A4 B5
    Scan: 01,02,03,08,15,17,25,35,45,55,56
    Skipping Address 15-Airbags
    Address 35: Centr. Locks
    Controller: 8L0 862 257 G
    Component: ZV-Pumpe, DWA, Funk D08
    Coding: 13130
    Shop #: WSC 06325
    9 Faults Found:
    01367 - Central Locking Pump Run Time Exceeded (Likely Leak)
    35-00 - -
    01371 - Shareware Version. To Decode all DTCs
    35-00 - Please Register/Activate
    01374 - Shareware Version. To Decode all DTCs
    01370 - Alarm triggered by Interior Monitoring
    35-00 - -
    01369 - Shareware Version. To Decode all DTCs
    01365 - Shareware Version. To Decode all DTCs
    29-00 - Please Register/Activate
    00991 - Interior Lights
    28-00 - Short to B+
    00955 - Shareware Version. To Decode all DTCs
    09-00 - Please Register/Activate
    00956 - Shareware Version. To Decode all DTCs
    1999 S4, MIJ Performance exhaust with 100 cell cats
    g60leigh's Avatar
    Jun 2007
    Stockton on Tees
    1,309
    pm me your email address and I will send you a PDF of audi fault codes
    2001 S3 (AMK)
    AEM WMI Kit, Black Silicone Hoses, Badger5 TIP with Cone Filter, AH Fabrications FMIC, Relentless Manifold Downpipe & Sport Cat, Miltek Cat Back Exhaust, VAG Aero Wipers, Forge FMDV008 Re-Circ, Revo Stage 2 Remap with SPS+ Tweaks, 2.0 TFSI Coil Pack Mod, B&M Short Shift, RNS-D Retrofit, Brembo & B5 2 Piece Rotor Conversion
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,907
    looks like all those faults are in the "central locks" section. Its probably mostly nothing, as things like alarm activations and suchlike are logged in there...
    The one to worry about is that pump run time exceeded warning. I'd clear the codes and see if they return, if the run time warning does return you have a vacuum leak in the door pipework.
    As long as there are no fault codes in the "engine" module then your engine itself is fine.
    TD5 Land Rover Defender build
    Broken Byzan's Avatar
    Photographic Moderator
    Apr 2004
    Cardiff, United Kingdom
    12,357
    ^^ i agree with aragorn, i would be 99% that the codes are nothing, it will have things like alarm triggered by door openeing,and key no2 not having been seen in a while etc etc
    Any chance of that PDF Leigh? to my msn addy?
    Apr 2004
    528
    Cheers lads, I found the codes on the ross-tech site. Does not look like anything serious.
    I notice that the scan didnt check the airbag. Will have to do it again, scanning the airbag.
    Blue_Thunder's Avatar
    Feb 2007
    Liverpool
    1,691
    Don't think you can scan the airbag with the shareware version.
    Mo power, mo problems
    Apr 2004
    528
    While VAG-COM is the undisputed king, are there any other applications that offer similar features?
