AH FabricationsSky Insurance
Results 1 to 14 of 14
    Oct 2005
    Essex, UK
    1,222
    Turbo Downpipe to CAT
    Hi people,
    Hope you've all had a good Christmas, I've lent my car to my dad today, and got a phone call earlier saying that there was a problem.
    He went into Kwik-Fit, and got told something along these lines:
    The turbo has got detached from the CAT, or something. There was a mention of the turbo downpipe, should go into a flange, which attaches to the CAT. - Does this sound right.
    Also they say driving it could damage the turbo, would you guys agree, as would rather get the car back here to be looked into by someone I trust (ie not Kwik-Fit).
    It's not a hole or anything, but a clean break, as if it's come apart, no rust....
    Any help would be appreciated....
    thanks
    VW Passat 2.0 TDI Sport
    2005 - 55 reg.
    A4 Avant 1.8T Sport - Sold March 09
    1997 - R reg.
    Oct 2007
    2,597
    The CAT attaches directly to the turbo via a fairly chunky flange, never heard of one break. With the heat generated by the turbocharger, it's very unlikely it would ever rust through.
    I can only imagine the bolts have worked loose, and it's blowing.
    Of course, it's not impossible for the flange to crack, especially if the bracket that secures the down pipe to the transmission is missing / not attached.
    Driving it home won't cause any turbo damage, it'll however be load as hell, and would probably spit flames from the open / detached part.
    "Stick a V8 in it!"
    Glenrothes, Fife, Scotland
    14,905
    The cat bolts directly to the turbocharger...
    The downpipe then bolts to the CAT.
    How far is it from the garage to your home? Its not really possible to break the turbo by driving it with no exhaust fitted, but driving it with a leaking exhaust over a great distance (say hundereds of miles) probably isnt a good idea, as its dumping hot exhaust gas into the engine bay.
    Kwikfit are arseholes, so dont let them do anything to the car. If you must, take it to another garage nearby, if you cant get it home.
    TD5 Land Rover Defender build
    Oct 2005
    Essex, UK
    1,222
    Thanks for this Siena.
    Would it likely be just replace a bracket or something, good to know it'll cause no damage to the Turbo, what about the CAT, will this also be fine?
    From what I've been told, there's no sign of damage, it's just loose, not secured to anything.
    Thanks again
    2005 - 55 reg.
    1997 - R reg.
    Oct 2005
    Essex, UK
    1,222
    Yeah, not planning on letting Kwik Fit touch the car, I'd agree with you there Aragorn.
    About a 100 miles to get it home again.
    If all else fails, I'll get RAC to tow it back again lol, then deal with it. Pay for the service may as well use it.
    2005 - 55 reg.
    1997 - R reg.
    Oct 2007
    2,597
    Sounds like the bolts have worked loose then.
    As Aragorn said, it could be a detachment at the CAT-to-turbo, or downpipe-to-CAT.
    From what you say, it sounds like it's the downpipe-to-CAT that's loose / detached.
    As long as it's not hanging down, and likely to catch on anything whilst driving, I'd advise your dad drives it home.
    Oct 2005
    Essex, UK
    1,222
    thanks again!
    2005 - 55 reg.
    1997 - R reg.
    Oct 2007
    2,597
    Let's know how you got on.
    Purple Princess's Avatar
    Jun 2008
    Button moon with mr spoon and gang
    1,026
    Std failiure, the cat has seperated from the flange. Will need to be re welded thats all. Easiestway is to get it tacked on in place then removed to be welded properly. Its to do with the different cooloing charceristics of the tubular pipework and the solid flange/weld etd
    Good luck
    Follow us on Facebook-Stacey-Byzan Photography-
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,824
    If the welding don't work I have a CAT from my car I could sell you plus it happend to quite a few cars where the CAT breaks clean from the flang.
    Oct 2005
    Essex, UK
    1,222
    Yep car is home now, and the CAT has separated from the flange.
    I don't have any welding equipment, and Audi won't weld it. LOL.
    See what I can find first, otherwise prob be a new CAT.
    2005 - 55 reg.
    1997 - R reg.
    docurley's Avatar
    Dec 2003
    UK, London, SE
    3,824
    I would say have your engine and Trans mounts check because excessive movement can cause too much stress on the exhaust causing the CAT to break.
    "Stick a V8 in it!"
    14,905
    Forget the main dealer. Just find a small local garage and take it there, i wouldnt expect to pay much more than 50 for a garage to weld the cat back together. Although a new (non-Audi) cat isnt much more than that, i baught a bosal CAT a few months back for my cars MOT and it cost about 70 from a local motor factors.
    Oct 2005
    Essex, UK
    1,222
    Thanks for all your help guys, a friend & me brought a welding machine from Halfords, 60 so cannot argue with that, went halves, as he was wanting one anyway, and he welded it on again for me. Seems to be holding so far.
    Thanks for all your help, hope you all have a good new year.
    2005 - 55 reg.
    1997 - R reg.
